Advanced/service menu settings got adjusted and want to change back. Anyone have a screen shot of their "mute 1 8 2 power" menu to show me the default settings, specifically those in the Options menu for Front Color, etc.
SOURCE: convergence settings
7 8 9 to select R G B, 4 to select moving part a line, full line or the whole matrix. S.mode to save your setting. Adjusting using arrow keys.
SOURCE: TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
SOURCE: My HDMI 1 is dull but when i put it on HDMI 2 its
Hi chaz,
I see that your HDMI 1 is having problems when used and on the HDMI 2 everything is ok and clear.
I believe this cannot be fixed since this is going to be a hardware issue, there are no settigns for the HDMI to change any settign rgarding video, the only setting you can get is for the whole LCD TV itself and regardless of what input you use the settings will be the same.
You may need to have that HDMI port check from the manufacturer if you still have warranty on your LCD tv.
I hope this helps.
Have a nice day,
mvincentc
If it did work before, it should work now. But if you are connecting a new device, make sure you are using the right inputs.
Yoou still can get the manual online, but to point out what I mean I send one picture about how to connect (Only one example) where you have to use 3 colours on the cable.
When connecting a video recorder (low quality, you only need 1 colour, for the composite entry (Yellow)
The link is for the manual:
http://downloadcenter.samsung.com/content/UM/200307/20030708161858250_SPN4235_00487A_0514.pdf
Testimonial: "Harrie I appreciate your providing this input but you are missing the Point along the way... If I am getting a CRISP PICTURE, then I must have the Video AV (Yellow) into the correct input. I also have the Red/White (Left/Right) in the correct places. What I am missing is WHY would there be NO COLOR but a CRISP Picture? This is a Used TV that a friend of mine was given and it does not have Color for a Picture from an External Input but the Menu DOES have color. I have tried to make changes to the MENU but nothing seems to work and it is ONLY a BLACK and WHITE Picture. Any thoughts as to WHY an Input would limit Color?"
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
