Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
hugh sauers Posted on Apr 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What brings on the P1 indication on the hobart dish washer
Wrench P1 indicator
kasper aung
Level 2:
Habit-Forming:
New Friend:
  • Expert 43 Answers
  • Posted on Oct 18, 2016
kasper aung
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
43
Questions
0
Helped
51859
Points
102
Possibly the thermistor of wash tank is faulty.
Ricardo311
Level 1:
Habit-Forming:
  • Contributor 36 Answers
  • Posted on Jul 11, 2016
Ricardo311
Contributor
Level 1:
Habit-Forming:
Answers
36
Questions
Helped
18406
Points
71
P1 = Wash tank probbe assy failure
3 Related Answers
Anonymous
  • 640 Answers
  • Posted on Jul 28, 2008
SOURCE: Hobart LXIH displays P2
The rinse thermistor is bad,look on the back of the machine to the right and you will see 2 black wires with a plug that screws into the vac breaker this is the probe.I bet when the dishwasher goes into the rinse cycle the temp jumps all over,let me know.
Anonymous
  • 41 Answers
  • Posted on Dec 09, 2008
SOURCE: wrench and code p3 display
this is a probe booster error your probe failed replace it
Anonymous
  • 6 Answers
  • Posted on Sep 12, 2009
SOURCE: P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Testimonial: "You were right! can you help mr with a P2 error code?"
1helpful
Hi i am getting a P1 error on a HOBART AM15 ELECTRIC DISHWASHER
Most likely sump temperature probe needs replacing.
I have a Hobart Dishwasher model LX30, it seems to stall when in the fill cycle from the start, which blocks any further function except shutting down, on the screen there appears a wrench insignia.
Hobart LX30H ML 104354 Manual Page 28
According to the manual ... the wrench icon comes on with OTHER codes for the LX30. Did you get a flashing P1, P2 or P3?
Or for that matter, get any associated E codes to come up?
Depending on the P or E codes there are fixes discussed on prior Fixya answers for this machine ... search there for more help
1helpful
Indicates problem with the temperature probe. Look in the tank where the float is and check to see if it is covered with debris. The float has a magnet that collects metal particles. The metal probe that is under the float is the temp. probe.
I have a am-14 hobart washer. having problem with rinse temp indicator. it is fine for the wash then the temp gauge is jumping around, could it be the thermostat?
Your rinse temperature sensor that is a tiny probe in the water piping (top rear of machine) needs replaced. Hobart part # 00-294692. It costs about $84.
6helpful
2answers
2answers
HOBART AM15 DISH WASHER ERROR(E1)
After checking the service manual, I find no code for E1. There is a P1, or other E codes. Please list ML number.
2helpful
2answers
Hobart lx 40 - problem D 1
Does it show a wrench icon and P1?
error codes are p 1to 3 for probe errors, or E1 to 7 for error codes.
P1 is the probe on the wash tank. It's a thermistor with two black wires to a white connector. There is another on the booster front (P2) and a 3rd on the rear airgap, (p3). You could try exchanging 1 and 3 to see if the fault changes too. You have to drain the booster to swap P2. If it can't determine the wash tank temp, it won't know to control the heat and shows the error.
3helpful
Wrench and code p3 display
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
