I need to know were the fuel relay is
SOURCE: E.E.C fuse keeps blowing in 1991 Ford Explorer
if you replaced fuel pump i would look at backward wiring when replaced and i would start at the source of work if your vehicle was working fine before replacement then 9 out of 10 it will be your fuel pump wireing
sometimes when putting wireing back together the connectors have the missing clip and in turn you can turn the wireing in both directions now where positive is touching the ground on both sides of connector kris kross problem check your work this is crucial use a test light to find the right wires where they go
SOURCE: need to know flash relay position in fuse box diagram helpful
i need the 2003 ranger fuse box diagram can i get it for free? and where
SOURCE: 1991 civic fuse box diagram
1992 civic but this is probably the same as yours. http://autoforums.carjunky.com/autof...A_CIVIC_P3020/
SOURCE: i need a 2002 ford ranger fuse box diagram and afuel pump relay switch diagram
Hi
go to www.motorcraftservice.com then click on the owner guide and put in your truck information
then choose the 1st owner manual printing and should be between page # 184 to 200.
Good luck and I hope this will awnser your question.
SOURCE: on a 1991 geo tracker trying to find location of fuel pump relay?
The fuel pump relays are mounted on an "L" bracket underneath the ECM. Both have something to do with the Fuel pump. Be careful not to get it confused with the horn relay it is in the same vicinity (under the dash on the drivers side).
