GE 30524ee3 3 Headset Corded/2 Cordless Dect 6.0 Answering Sys Lcd Display Used Logo
M
Margaret Mattlin Posted on Apr 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a power adapter for telephone base for model 30524
I lost this cord and am seeking a replacement
Robert A. Watson
Level 3:
  • Master 774 Answers
  • Posted on Apr 04, 2015
Robert A. Watson
Master
Level 3:
Answers
774
Questions
0
Helped
302859
Points
2079
Not a problem. Take the base unit with you to Radio Shack and they will get you a proper replacement. (The numbers on the plug in to the unit will say how many volts Direct Current are required to operate is properly and the tag underneath will also state how many milliWatts of power are required at that voltage.) The key is buying the proper plug in end that fits the socket. Radio Shack has units with several socket tips so you may select the proper one. Make sure the polarity of the socket plug you use matches the wire polarity... the stripe on one side of the power cord is the + side on the socket tip.
johnny rebel
Level 3:
Top Expert:
  • GE Master 10,875 Answers
 johnny rebel
GE Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2938470
Points
47944
I have an old phone KX-T3000H and I need parts for it . Cap for the battery on the phone and another battery cap for the base . Does anybody know where can I purchase them.
That type of spare is not normally available on phone sets. I guess you could contact Panasonic.
Cordless & Corded Replacement Parts' Panasonic US
shop.panasonic.com > telephone-replacement-accessories
Handset Charger. PNLC1046ZW. Replacement Handset Charger for select Digital Cordless Answering Systems. Does not include AC Adapter or Handset.
Official Panasonic Cordless Phone & Corded Telephone ...
shop.panasonic.com > cordless-corded-telephones > cor...
Shop Panasonic cordless and corded telephone accessories from batteries, headsets, replacement parts and more.
Panasonic Telephone Parts and Accessories
panasonic.encompass.com > modelbrowse > MSC
Panasonic Telephone from Encompass parts & accessories. ... and Accessories. Panasonic Replacement Parts ... Cordless Phone With Answering Machine, 7.
2answers
Panasonic PNLC1017, our landline telephones do not work. I've changed batteries, the phone screen reads check tel line. Please help!
The PNLC1017 is the charger for the handset of some Panasonic cordless phones. One of the compatible handsets is the KX-TGA660 which works with the KX-TG4112 system.
However, the 'Check tel line' message indicates a problem at the base or the POTS (Plain Old Telephone Service) telephone line. The system is not hearing the dial tone. Check that the power adapter is plugged in to a live outlet and is warm. If it's cold, than the power transformer is not working and the base has no power. If there is power, check if the handset message disappears when the handset is close to the base. This is usually rare but indicates a transmitter/receiver in the handset or base is not communicating properly. You can try to de-register all handsets and then register them again.
To check the phone line, I prefer to use an older corded phone. These don't require power to work. First, try a new phone data cord (RJ-11) between the base and the wall jack. (I've seen someone accidentally use a handset cord which doesn't work.) Test if there is a dial tone when this cord is plugged into the test phone. If there is a dial tone, then if the cordless phone base didn't work with the replacement cord, the base is faulty. Replace it or contact Panasonic if the system is under warranty. If you have a DSL fliter, this may be damaged. If it's inside, replace it. If it is in the service box, ask your telephone provider to check it.
If there is no dial tone, you need to locate the other phone jacks for that phone line. Find where your phone service comes in as well. Check if there is a dial tone on another jack for that phone line. If there is no dial tone, check the service box for an RJ-11 jack, Test for a dial tone there if you can plug in the RJ-11 cable. If you have a dial tone at another jack, then the problem is local to the first jack's wiring. You can open the jack and check for loose wires. There are two styles of jacks - screws or punch-down. For the screw terminal, strip the insulation and wrap it under the appropriate screw. For the punch-down keystone jack, you need a punch-down tool. The tool is available from most home improvement/building supply stores, in the wiring section. Do not strip the wire. Use the tool to press the wire down into the correct slot on the jack. See https://www.lanshack.com/wire_phone_jack.aspx for the wiring diagram.
If you can't test the phone line or there is no dial tone at the service box, then you need to contact your telephone provider. It used to be that the provider would always test and fix outside problems for free. Some telephone companies are trying to stop repairing copper wiring. If you have a dial tone at the service box, then the problem is somewhere in the inside wiring. You may want to get someone to find a broken wire in the wall for you. Your telephone company service technicians will do this for a fee.
I hope this helps. I've had the check tel line issue times several times at my home. Twice, the outside line was damaged by mice and repaired by my telephone company. Once, a lightning strike damaged the DSL filter; it was promptly replaced. Other times, the line was damaged by contractors digging too close to the underground utilities. The contractors got the wiring repaired. When our service was switched to a fiber-optic system, we lost one telephone jack when the installer simply didn't plug in the wire. We found the loose wire behind the siding and plugged it into the port in the service box ourselves. Since then, we lost telephone and other service intermittently when the modem card in the service box was failing. That was also replaced by the telephone company technician.
How do I forward my phone number on a Dect 6.0 cordless phone model 30524
Do you mean the GE DECT 6.0 30524 corded/cordless phone? For this landline telephone, you can switch a call from one handset to another (or the base) by using the Intercom feature. Press del/int on the handset or Int on the base and choose a handset number (use the CID +/ phonebook -) buttons (if multiple handsets are registered) or select base from the handset. Press Menu/OK to page the other handset or base. Once that device answers the incoming Intercom call, press and hold Del/Int or Int to create a conference call (both handsets or handset and base listening). Press Del/Int or Int to switch from the Intercom call back to the call on hold. Hang up on the first handset if the person on the second handset will continue to speak to the original caller alone. See pages 24-25 of the manual to see the directions. The direct link to the manual is currently https://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf .
For any landline phone, to forward a call to another phone number, you need to subscribe to a forwarding option with your telephone company. Check their information for initiating call forwarding.
If you have a different 30524 phone, please add a comment with the manufacturer.
I hope this helps.
Good day, We have a Digital Cordless telephone DECT GAP, MODEL C601. It was working find and all of a sudden there's no dialling tone. I did reboot but still nothing. Bets
Is the power adapter warm? If the power transformer is cold, the base isn't getting power and can't communicate with the handset. Try a new telephone cord between the base and the jack. The cable can fail. (Make sure it's a line cord. I've seen someone plug in a handset cord here and that won't work.) If you have a DSL filter at the jack, you may need to replace it.
For the rest of the phone line diagnostics, I like to use an old wired telephone. Then you don't need to plug in the power adapter at the test locations. Check if you have a dial tone at the jack with the test phone. If you do, then the DECT GAP C601 phone is faulty. If it is, contact the manufacturer if the phone is under warranty (one year). Replace it if it isn't.
If there is no dial tone, use the test phone check for a dial tone at another jack for that line, if available. If you have a dial tone, then the problem is with the wiring to the jack or in the jack itself. Open the wall plate and look for loose wires. If a wire is loose, reconnect it in the correct location. There are two standard connections - screws or keystone jacks. For the screw type, strip a portion of the wire's shielding. Loosen the correct screw. Wrap the wire under the screw and tighten. For keystones, do not strip the shielding. Get a punch-down tool from a hardware store. Use this to push the wire into place. See https://www.lanshack.com/wire_phone_jack.aspx (for the US standard wiring pattern).
If there isn't a second jack available or there is no dial tone at that jack, find your telephone service connection. Open the panel if you can and look at the terminals. If there is a RJ-11 connection, plug in your test phone and check for a dial tone. If you have a dial tone here, then the problem is with the wiring inside your building. You may want a professional to find and repair the break in the wires. If you can't test the phone line, contact your telephone company. They should test the line for you. Outside problems should be fixed by the telephone company (in the US) However, some companies are trying to avoid repairing copper wiring.
I hope this helps.
(My phones have lost dial tone due to nearby digging projects that accidentally cut a line. I've had rodents damage the wiring outside. (I have underground telephone lines.) I've had the DSL filter get damaged; in my case that's outside and the telephone company replaced it. I've also had a contractor fail to connect all of the wires during a service upgrade. Only one jack had no dial tone. It was easy to fish the misplaced wire back up from behind the siding and plug it into the panel. I've even lost dial tone intermittently when the fiber-optic modem card began to fail. That was fixed by the telephone company.)
I have a Dell laptop with lost power cord what could I use in place for a power cord to use laptop
There are many replacements that can be found from your laptop manufacturer or websites like Newegg or Amazon. Many third party brands make replacement power adapters often for lower costs.
You first need to determine your power needs based on your computers model number.
How do i get volume on my binatone 3325 handset
Press C/8 to unmute the microphone.
complete installations
Plug the power adapter
& line cord
into the base station.
Plug the power adapter into a 230Vac, 50Hz
mains socket, the other end of the line cord
into your telephone line socket.
Warning: Always use the line cord provided in the box.
Other line cords may not be compatible and may not work.
Warning: Only use the power adapter supplied.
Others will result in non-compliance with the safety
specification EN60950, and will invalidate any approval
given with this apparatus.
Warning: The Base unit needs mains power for
normal operation, not just for charging the handset batteries.
Installing and charging the batteries
Slide open the battery compartment cover.
Place the 2 batteries with the correct polarity,
as shown.
Slide the battery compartment cover back.
Put the handset on the base and charge for
15 hours before first time use. The handset
beeps when charging starts.
Warning: Only use the AAA size NiMH rechargeable
batteries.
If you have a Broadband Line
If you connect your telephone to a line with a broadband connection, you will need to
insert a micro-filter between the telephone and the telephone line, otherwise you may
get interference between the telephone and the broadband, which could cause
problems.
In a home with broadband, every telephone must have a micro-filter connected, not just the one at the telephone point that your modem is connected to.
If you need more broadband micro-filters, contact your broadband provider.
Connection and Conditions for use:
You can connect your phone to a direct exchange line (DEL) on a local
exchange with its own phone number; to an extension socket
connected to a DEL; or to an extension on an approved compatible
PBX. Do not connect as an extension to a payphone.
The ringer equivalence number (REN) of all equipment (phones, fax
machines, modems, etc.) connected to an exchange line must not add
up to more than 4, otherwise one or more of them may not ring and/or
answer calls correctly. This phone has a REN of 1, and most other
telephones have a REN of 1 unless marked otherwise.
Handset - Base Connection
1) When purchased, all handsets are already registered to the base unit
and should link to it when they are all powered up.
2) To use your cordless handset and base unit together, you must be
able to establish a radio link between them. The signal between the
handset and the base is in accordance with the normal standards for
a DECT phone: Maximum range up to 300 metres outdoors or 50
metres indoors. Be aware that:
> Any large metal object, such as a refrigerator, mirror or filing cabinet,
between the handset and the base unit may block the radio signal.
> Other solid structures, like walls, may reduce the signal strength.
> Other electrical equipment may cause interference and/or affect the range.
3) Do not place close to another telephone, a TV or audio equipment - it
may cause interference.
4) Out of Range warning. If you hear a warning tone during a call,
and/or the sound in the earpiece becomes faint or distorted, you may be
going out of range of the base unit, so move nearer to the base unit
within 20 seconds, otherwise the call may be cut off.
My Sony cordless handset doesn't work and displays "S/C Invalid".
  1. Place the handset in the base.
  2. Unplug the AC power adapter from the telephone base.
  3. Disconnect all the telephone lines from the telephone base.
  4. Allow the telephone base to remain without power for 1 minute.
  5. Connect all the telephone lines to the telephone base.
  6. Plug the AC power adapter back into the telephone base.
1helpful
Dont know how to hook it up to phone...have S10A and S11 model plantronics corded headsets
Turn over the S11 base and insert the headset slot. This is at the top of the base. Remove the handset cord from your telephone base and plug into the handset jack (there will be a picture). Using the short cord that came with the S11, plug into the line jack on the back of your base and the other end into the slot on your telephone where you removed the handset cord. Plug the headset cord into the headset jack that is on your S11 base. Connect the the A/C power adapter to the S11 A/C jack and a wall outlet. Put on the headset. Press the handset/headset switch and pick up the handset off your telephone, set it aside to make calls. Slide the configuration switch (on the side of the S11 base) until you hear a clear dial tone.
Good luck from Headsets Direct!
2helpful
No dial tone after an electrical storm . I had to replace the AC adaptor. Everything else works.
Having to replace a power adapter indicates a pretty severe power surge that could easily have destroyed your Cordless Phone Base station delicate electronics!
But to ensure that it is not a faulty telephone line, plug a working corded telephone directly to the phone wall jacket and see if you get a dial tone.
Hope it helps: let me know how you go.
4helpful
2answers
My infor globe does not show the i d caller
for most problews, including caller id, follow these instructions in order:
Put the battery into the battery compartment and connect to the
connectors inside the battery compartment.
Connect the power adapter and telephone cord into matching jacks on the under side
of the base.
Plug the power adapter into the electrical outlet. Plug the telephone cord into the
telephone socket.
my caller id was not working, but everything else was. I followed the instructions above EXACTLY IN ORDER and the caller id is now working.
Top GE Radio Communications Experts
eradiostore
eradiostore
ADMIN Andrew
ADMIN Andrew
Jim
Level 1 Expert
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
