Question about Kenmore Elite 21086
Why does my washer do nothing after the water stops filling ?
I think my washer my need the sencer that tells it that the lid is closed
  • tom cassidy
    tom cassidy Apr 12, 2015
    Hi Rebecca Dunn, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    New Friend:
  • 72 Answers
Your water pressure switch could be not working.
go to
www.sears.com/appliancerepair.com
Check your agitator belt also.
You can also call sears and they will let you talk to a technician whom can offer more help.SM63MK
Posted on Apr 12, 2015
  • Ellen Tumey
    Ellen Tumey Apr 12, 2015
    But it sounds like your lid is messed up.Go to www.panhandleparts.com
    they can walk you through what needs to be done.
6ya staff
SOURCE:
robert samples
  • 1314 Answers
SOURCE: Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Posted on Dec 31, 2007
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Kenmore Elite Washer Problem
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place.
Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. NOTE: You DO NOT have to drain the tub to repair the lid switch.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions or need help locating the correct part, please let me know by posting comments.
Posted on Apr 08, 2008
ned_san_jose
Ned Halaweh
  • 240 Answers
SOURCE: Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Posted on Jul 16, 2009
plante3pups
  • 274 Answers
SOURCE: My Kenmore Elite top loading washer keeps filling
its suppose to start with lid down,the draining may be a faulty water level switch so this needs replaced.
Posted on Aug 29, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: kenmore washer not working
Likely the motor (or controller) is bad. Further tests are necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Washer fills with water and stops
You possibly could have a bad lid switch. The machine may think you still have the lid up and that is why it stops and will not do anything else.
Feb 10, 2015 | Roper RAS8445KQ Top Load Washer
Whirlpool - Filled with water to wash and stopped. Pushed in and turned to see if I could get something to happen or reset the cycle. Does nothing at all.
if the washer is full of water and will not continue it needs the lid switch replaced : the lid has to be closed so the washer will agitate and spin the lid switch is under the lid on the right or rear left
Apr 25, 2010 | Whirlpool Washing Machines
Whirlpool washer wtw5200sq0 fills with water and stops. no agitation - no sound -- replaced timer but nothing
instead of timer soinds like a faulty lid switch, the unit not recognizing the door is closed so will only fill with water
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Top Loader LSB6000PQ0 fills up with water but that's it
you probably closed the lid to hard and broke the switch that tells the machine that it is closed. So the machine thinks the lid is open and for saftey reasons will not operate. I had the same problem. You can buy a new switch for about $10 or you can simply cuts the wires for the switch and wire them together. If you do this be warned that the machine will never know if the lid is open or closed. The machine will assume that the lid is always closed. But it will work also.
Jan 28, 2009 | Whirlpool LSB6000PQ Top Load Washer
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool thin twin filled with water then stopped!
Not sure about the dryer but there are a couple things that could cause the no draining issue.
You could have a leak or block in your pressure hose. Basically there is a thin, clear tube inside the cabin that attaches to the tub on the lower right side. If this has a leak or is clogged then the washer has problems filling and draining.
The other possible problem is a broken lid switch. This is an easy fix. Basically, the mechanical mechanism that goes down when you close the lid does not work properly so when it comes time to drain, the washer actually thinks the lid is open.
For both of these you would need to open cabin. I posted instructions for that here:
http://www.fixya.com/support/t1885690-whirpool_twin_washer_dryer_lte5243dq3
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer model 110.24642300 fills with water and then does nothing. Tried other modes such as spin, but it stills does nothing.
The sensor which determines whether or not the lid is down may be going bad.
To tell - turn the washing machine on and let it fill with water. At this point, the washing machine stops. So raise the lid and place a screwdriver into the hole around the collar of the washing machine. This is the same hole that the lid, when closed, presses into, activating the sensor to notify the machine that the lid is closed so it can begin washing.
Aug 23, 2008 | Washing Machines
Kenmore Top Loader Washing Machine
check to make sure the lid switch is closing when you close the lid. When you open and close the lid you should here a click similar to a wall light switch.
Also check the lid to make sure the tab has not broken off that actuates the lid switch, your model may not have a tab on the lid.
ask more questions is lid switch is functioning,
Jul 16, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
