Question about Jamo The SUB 660 is intended to be used with high-performance loudspeaker systems
Hi, I have jamo sub 660, But i need complete schematic diagram, where can i get it..
    Top Expert:
  • Jamo Master
  • 30,786 Answers
If you are a service centre for Jamo then you will be able to get one otherwise they are not available.
Posted on Dec 06, 2019
6ya staff
SOURCE:
sanjin
sanjin becirbegovic
  • 56 Answers
SOURCE: I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Posted on Mar 18, 2008
Dennis McCollum
  • 137 Answers
SOURCE: Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Posted on Apr 20, 2010
shamifernand
SOURCE: Please help! Jamo SUB 300
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
Posted on Aug 20, 2011
Robert Rankin
  • 378 Answers
SOURCE: i want jamo sub 1810 circut diagram
Check out this link:
http://2getdtv.com/directv/stereo_receiver_codes.html?phpMyAdmin=ed9585cdc5a4551847999cb4dbcce76a
Posted on Feb 25, 2012
Cody J Turner
  • 28 Answers
SOURCE: i have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Posted on Sep 13, 2012
Hi My problem is that my Jamo 200 sub sounds very
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
Oct 26, 2013 | Jamo SUB 200 Subwoofer
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
Sep 13, 2012 | Jamo SUB 200 Subwoofer
Jamo sub 660 wont come on
Hi,I have the Jamo sub 660 and it won't come on,I took it to my technician,and he told me that it has a broken ic,the broblem is that he cannot replace it cause the number on it is scratched,does anyone know what the number is pls! Thanks in advance Joseph
Aug 25, 2012 | Jamo Audio Players & Recorders
I want jamo sub 1810 circut diagram
Feb 22, 2012 | Jamo SUB 1810 Subwoofer
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
thank you
ron
Jan 08, 2011 | Jamo SUB300BA SUB 300 Powered Subwoofer...
JAMO SUB 650
hi
since it is a powered speaker, probably it just needs a sound signal which you can get from the headphone socket. please double check with someone else.
May 26, 2008 | Jamo D 4SUB Subwoofer
Jamo 250
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
Jan 11, 2008 | Jamo D 4SUB Subwoofer
Jamo The SUB 660 is intended to be used with high-performance loudspeaker systems Logo
727 people viewed this question
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
rjivaro
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
