Question about Lenovo IdeaPad Computers & Internet
Cant connect lenovo y410 to external vga , l have tried fn plus f3
    New Friend:
    Problem Solver:
  • 7 Answers
Hi
Have you install your graphic driver properly?
1. First you must check if your graphic driver to the latest update.
2. instead of using fn + f3 try using windows + P
3. check your vga cable if not broken try other vga cable or use hdmi cable.
Posted on Jun 17, 2015
6ya staff
SOURCE:
patemi
Pat Batta
  • 366 Answers
SOURCE: Dell Latitude D600 - Screen goes blank while booting
Check you config against this tutorial
Posted on Jan 12, 2009
cpenzes
DEKR
  • 1102 Answers
SOURCE: White Screen for Lenovo Y410
can you try and power up in safemode
by continuosly pressing f8 during startup
see if you can get in safemode
Posted on Jan 13, 2009
Anonymous
  • 170 Answers
SOURCE: Wifi driver of Lenovo Y410
Here is the link for Intel....you will need to know the model #
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17227
and here is the link for vista drivers at Lenovo
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=6
I hope this helped...if so please rate me ...thanks ..The Fang
Posted on Mar 26, 2009
Edward Jennejohn
  • 244 Answers
SOURCE: connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Posted on Sep 06, 2009
Testimonial: "thanks for the info but now trying to hardwire the laptop to the external monitor...wish me luck!"
SOURCE: broken screen, external monitor via VGA won't
please call the tech support line 1-800-426-7378 for immediate pc repair
Posted on May 11, 2010
Lenovo g470 vga display issue
fn + f3 change display
fn + f5 wifi on/off
May 03, 2017 | Lenovo G470 Core I5-2410m 2.9ghz 4gb 500gb...
Does Lenovo 3000 Y410 support dual monitors
Yes.
1) Laptop OFF, monitor OFF.
Connect a VGA monitor to the VGA port, on the back of the laptop.
The VGA port is on the right side, as you view the back of the laptop.
This is a basic example of a VGA cable, and a VGA port, (Connector),
http://en.wikipedia.org/wiki/VGA_connector
NOTE* Color does Not matter.
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
Press, and hold down on the Fn key, and at the same time tap once on the F3 key.
No?
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and tap again on the F3 key.
(The Fn key is down at the bottom LEFT corner of the Keyboard.
The F3 key is at the top of the Keyboard.
The F3 key is the Display Toggle-Over key )
Need more information post in a Comment.
Regards,
joecoolvette
May 18, 2012 | Lenovo 3000 Y410 (59012354) PC Notebook
I tried to hook up an external "Sharp" monitor to my Lenovo G555 using a VGA chord. It did not show on the monitor. I went through the control panel and picked "Connect To a Projector"....
Do you still have your Lenovo G555 manual? "Try to read when connecting to the projector section"
I will give you some universal function keys to solve your problem
press and hold this:
Fn F3
Fn F4
Fn F5
Fn F6
do this one at a time
others does not function with Fn they use ctrl button. Try to press and hold ctrl with the button mention above with not pressing Fn
Jul 26, 2011 | Computers & Internet
Hi all, when I press Fn+F3 then screen is sent to external projector, but my notebook's screen became black. What I should do?
The Fn+F3 key toggles between these display settings when you press these keys again.
To the external projector only.
To both the external projector and laptop screen
To the laptop screen only.
Repeat pressing the Fn+F3 keys will cycle through these screen settings again.
Feb 10, 2011 | Lenovo IdeaPad Y530 Laptop
Cant get it to work with laptop
power ON your projector and laptop
connect your laptop and projector with VGA cable and press
if your laptop PANASONIC or NEC (Fn+F3)
ACER, HP,SHARP,TOSHIBA (Fn+F5)
LENOVO, SONY (Fn+F7)
DELL, EPSON (Fn+F8)
FUJITSU (Fn+F10)
APPLE (F7)
If problem exist remove the VGA driver in your laptop and reinstall the correct driver not a standard display driver
Feb 09, 2011 | Panasonic PT L720U Multimedia Projector
Hai my y410's wireless is not turning on when i installed the new windows 7 on my y410 which originally came with vista
install drivers that you had for your windows vista for your wireless network adapter.
Hope it works..
Feb 14, 2010 | Lenovo 3000 Y410 Laptop
Wireless
Check to see if there is a wireless switch somewhere on the laptop.
Some use the FN key plus the F2 key, but many laptops have an actual switch that you have to turn on.
Also sometimes it's turned off in the bios, but not often.
Jun 13, 2009 | Lenovo 3000 Y410 Notebook
How do i auto switchoff my lenovo y410 laptop
I'm not sure if your referring to sleep mode or not but I hope this helps There are several specialty key functions on the Lenovo Y410...here is a list....good Luck....please rate me ...The Fang
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
Feb 19, 2009 | Lenovo 3000 Y410 Notebook
Computers & Internet Logo
59 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
