I just connected the main board A1727318A to Sony tv KDL-32XBR9
ISEND THE MAIN BOARD TO GET FIX . RECIEVE IT YESTERDAY AND TODAY I CONNECT IT TO MY SONY TV. JUST WENT I STARTED TO UPDATE IT IT WENT ON A STANBY MODE SHOUT DOWN AND RED LIHGT STANBY MODE STAYS BLINKING .
Re: I just connected the main board A1727318A to Sony tv...
How many blinks do you have?
Main Power 2 Times (PS Board, G2CE Board)
DC Alert 3 Times (BM3 Board, G2CE Board)
T-Con 4 Times (T-CON Board)
HDMI 5 Times (BM3 Board)
Backlights 6 Times (Inverter Board)
Temp 7 Times (BM# Board)
HFR Error 8 Times (LCD Panel)
Question edited for clarity and spelling 'board' - 'different'.
If the board number is the same, yes you can use it. The likely issue is whether the board is new or taken from a scrapped set and whether it is returnable.
dear
when we replace main board or panel in these modals software must up date other wise green and umber light blinked
please up date the software
thanks
M Nasir
check the voltages at pins leaving power board some have the sound pins printed on. if ok then check connection board. theres also a little pcb board attached to speakers. the red whit i think are sound leads to speakers. or speakers blown, check resistance
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Tries tv unplug,replug it back about an hour later for the tv for a resetting back to the factory setting.Go into the tv menu go to Audio Setting go down to do a resetting back to factory setting.These steps will help the tv to get the tv audio back.
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
