How di I fix the audio on my coby tv? I can hear a scratching sound only. I was able to connect to netflix via my ps3 and the audio worked. Is this something you can assist with
Re: How di I fix the audio on my coby tv? I can hear a...
Unfortunately the failure to mention needs repair by a qualified technician. The solution that is easily accessible by changing the main board , but are now discontinued . I hope I have been helpful . Bye Bye
Suggest connecting via the headphones jack or if available the RCA audio output jacks. If you connect via the headphone jack you will need to adjust the TV volume to a lower setting to avoid distortion/./ The The problem is that the optical output connection is a digital connection and depending on the digital format the Digital to Analog converter may not be a configuration that the audio stream to the stereo required for the tv/vcr in.
How does the audio sound using the Samsung Smart TV internal speakers>
Also under menus/audio/settings you may need to change the Optical output to stereo.
Netflix also has settings that will change the audio stream.
The DVD938 only has analog audio input (2.1 channel), thats why you have only a white (left channel) and red (right channel) audio connection from your ps3 to the home theatre. There is an option called PROLOGIC in the setup menu that will simulate 5.1 with the 2.1, it basically takes the 2.1 channels and splits it into all the speakers.
Your TV would have to have an AUDIO OUTPUT port (RED/WHITE) and that would go from the back of your TV, to the RED/WHITE input on the DVD938. All your other devices would go directly to your TV. After you do that, you change the input on the DVD938 remote to AUX.
If you are having trouble with audio just from Netflix and all the audio play back works then this sounds like you have a corrupted audio codex on the PS3.
The first thing I would do is uninstall Netflix from your PS3 and reinstall it. If this does not fix the problem I would reinstall the firmware for the PS3. If you still have trouble you may need to format the hard drive. The link below will help you do that if needed.
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
I had the same problem and tried everything and in the end turning off my tv and turning it back on again worked.. I also have HDMI setup through a samsung 1080p tv... I hope this helps someone :) I was so frustrated till I figured it out ;)
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
