The picture shows clearly for hours, then it will shade darkly on right side on screen off and on for a while; then it would clear up again.
SOURCE: Screen dark on right hand side at start up
Suggest return or exchange. This is a newest model, and on factory warranty, if can't return or exchange, you have to complaint it until the panel is replaced. in fact, it is 90% panel defective. right now the LCD panel quality is too bad.
SOURCE: We have a Sanyo 46"
We've had the Sanyo 1080p Flat screen TV for about a year and a half and the right side of the TV is black when we turn it on and after about 45 minutes in brightens. Sometimes it still has lines flickering throught he uper right.
Solution?
SOURCE: When I turn on the
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
