ok i have a 1998 durango with the 5.2L 318 engine. had trouble with a bad cell in my battery. I went out bought an optima red top battery for it 800cca. put it in and had same trouble. No start without putting foot on gas. wouldn't stay running without holding foot on gas. CPU has to relearn it's programming once you unplug it for long periods of time. mine was without power for about 2-3 weeks till i got new battery. Start with this.. first check under air filter make sure a squirrel hasn't made a mess under your air filter and it's clogging the air intake. Then pull off the lid to your injector cover ( the screw down lid coming from the air box ( with air filter in it) to "carb") make sure all your cables move freely. put that all back together and close hood. Start truck with foot slightly on gas pedal to get started. keep it at about 1k to 1500 rpm for about 1-2 minutes. Rev motor to about 2500rpm and let it die out if it will. Get out lock doors with key fob if you have it. if not make sure to lock doors. ( trust me it worked for me) let sit for 5 minutes. come back out and unlock door and relock door 3 times with fob ( if you have it ) or key if you don't have a fob. Then unlock it with the key and enter vehicle. Start truck as before and keep it around 1k to 1500 rpm again for about 30 seconds rev it up and should keep running. Mine did. I think the iac was stuck from sitting and has now since loosened up. Good luck hope ti works for you.
if the fuel filter hasn't been changed do so, if the fuel filter is ok and has been changed out due to this problem you will need to monitor the fuel pressure under a load and make sure it doesn't drop below 45 PSI, it it does you will need to replace the fuel pump and the fuel filter. U also do say if you have a check engine light or have had the system tested for trouble codes that may be triggered by this loss of power problem.
Have you changed the tps? The tps is like a dimmer switch with the idle being the lowest setting and everything above that being progressively stronger. If the switch is bad it will not advance spark or gas flow.
sounds like a typical throttle position sensor problem, ye before you get there check the air filter and make sure that youf fuel is not contaminated it is either your TPS or the air flow meter is going bad both are expensive sorry
