I AM A NOVICE USER AND NEED STEP-BY-STEP INSTRUCTIONS ON HOW TO GET SECURE WIRELESS IN MY TOWNHOUSE APARTMENT? CURRENTLY HAVE A DSL HIGH SPEED CONNECTION. WANT TO GET WIRELESS. WHAT DO I NEED AND HOW DO I DO IT?
SOURCE: ZyXEL adsl wirless modem router P660HW
To bring up the blue screen you need to open internet explorer (or whatever) and type the ip address given. In my book it says 192.168.1.1 after that you should get the blue screen. You can set up the connection then.
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
SOURCE: No DSL or Internet light
Does your mac book has a phone port? You can try that to setup a dial up connection an see if it will work.
SOURCE: connecting using wireless
I don't believe Zyxel supports only Zyxel products. Finally, after analyzing the problem between the zyxel and the router, I found a solution that worked and allowed me to network both wired and wireless connections here at home. Set your router to auto-dhcp settings. Clone the MAC address of your computer. After this is done, put OFF first the router but make sure that the cable from the router WAN port is attached to the modem already. Then, put ON the zyxel and wait until it is fully functioning (2 lighted LED lights) before you switch ON the modem. Let both units (router and zyxel modem)synchronize first about a minute or so. Then connect/put ON your computers.
I found the above procedure to do it step by step so as to avoid conflict signals during synchronization which seems to be causing the non-internet connection.
Hope this helps!
SOURCE: ZYXEL P-660HW-T1 V2 WIRELESS ROUTER MODEM WILL NOT CONNECT TO MY ISP
is your router connected to your ISP ? (does your dsl led light up ??)
if no! check your wires from phone to router!! and check your SPLITER !!! (i had the same problem, i got bad spliter !!! NEW BUT FAULTY !!!)
chears
