QuantumFX Quantum FX Universal Remote Control - Quantum FX REM-101 Logo
C
COURTNEY HARRIS Posted on Mar 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What button do I use as a setup button if there isn't one on my remote
coetzee_phil
Level 2:
Habit-Forming:
  • Expert 140 Answers
  • Posted on Mar 28, 2015
coetzee_phil
Expert
Level 2:
Habit-Forming:
Answers
140
Questions
Helped
78375
Points
403
Hi again
Use the "Device" key on your remote. I will upload another manual though.
Regards
Phillip
1helpful
Tryin to conect cox remote to my onn tv but the code isn’t working
MANUAL PROGRAM CODE SEARCH YOUR XR11 REMOTE TO YOUR TV:
1 – Turn ON the TV you will be using with the XR11 remote.
2 – PRESS AND HOLD the SETUP button (bottom left) on your XR11 remote until the LED status light (top of remote) flashes from Green to Red.
3 – Begin manual TV code search by entering 991 on the XR11 remote.
4 – The LED status light will flash Green 2 times.
5 – Repeatedly press the CHANNEL UP button on the XR11 remote to search through the TV codes.
6 – Keep pressing CHANNEL UP button on the XR11 remote until the TV you are programming turns OFF.
7 – After your TV turns OFF press SETUP.
8 – The LED status light on your remote should flash Green 2 times.
9 – Press the TV Power button on the XR11 remote and if the TV turns ON, your XR11 remote is programmed.
Be sure to hold the SETUP button until it flashes Green 2 times after your TV turns OFF.
TV remote needed
Universal remote codes for Samsung TV are: 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Buy one universal remote control, which have any one setup codes among the above said. Brand name of the remote isn't a matter.
Toshiba won't function with remote
All universal remote controls should have to setup with the TV by its codes. There are codes, given below, to synchronize the TV with remote control. Brand name of the remote control you have isn't matter. Check these codes. Proceedings also is given. If you want further details, check this link, and select the site 'Electro-help'. pull up older posts there for more details.
Setup codes for Toshiba TV are:
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Is this a universal remote or only for Toshiba devices? I have a used Zenith tv.
These are the setup codes for Toshiba TV. Brand name of the remote control isn't matter. If the remote control you try to synchronisze have any of the above said code, it can be used to setup with your TV. If not, it is not possible. If you wish to get more details about codes and setup proceedings, visit this site [Electro-help]. type in "electronicshelponline.blogspot" into the search box of your browser and click search. Pull up older post there. It is a blogspot site, in English language.
What remote can i use for my toshiba 20af44 TV
These are the setup codes for Toshiba TV, with universal remote control. Just buy one universal remote control, which have these setup codes. Brand isn't a matter. You can get this detail, by the code list, the remote control will have.
Universal remote
Setup code for RCA DVD playere is 0409
Buy one remote control which have this setup code in its code list. Brand name isn't matter.
Need to get a unversal remote one for all to work
These are the setup codes for Symphonic with universal remote control.
0053 0189 0227 0456 0024
Buy one universal remote control, which has one among these setup codes. You can get details about codes, from the code list attached to the remote control. Brand isn't matter.
I just purchased a Harman Kardon AVR 2650 and use it with a projector. It says to use the set up button and there isn't one. can't get on screen menu to set up
HI,
First of all check the HDMI connections. You have to connect the HDMI Monitor out to Your projector.. And HDMI 1 to blueray or to a dvd player what you have.
To access the setup on Harman Kardon avr Just press the AVR button on the remote control. You can find the AVR button on the lowest postion of the remote . When you press the AVR button the ON SCREEN menu will pop up. Do the settings you needed.
One more thing try to use HDMI cable wih a vertion of 1.4a.
If you are not able to get the AVR ON SCREEN menu through HDMI then connect the composite monitor out In the rear of the avr to the projectors composite video input. Select the projectors composite input.
Then press the AVR button. Connect the mic to your Avr which coms with it. Select the speaker setup From the menu. Then select Automatic setup.
If you need any more assistance feel free to contact me throug fixya or by mail.
My mail address is [email protected]
OK
My husband just purchased a iSymphony 19" LCD HD tv. The remote will cut the tv on and off but the menu button on the remote and on the tv does nothing when I press it. Won't allow me to run the...
Yes you should take it back because there isn't supposed to be a trick to getting the menu to pull up the menu. Is there a setup button as well...well that does not make a difference because the menu button on the tv itself is supposed to pull up the menu. If nothing is happening there is something wrong. Sometimes a television will prompt you to begin a setup sequence when you first plug it in including selecting a language, location, and etc. This will lead to the channel scan or ask you if you are connecting it to a cable or satellite box. If none of that was the case then you should return or exchange this television.
1helpful
Batteries are good. However TV isn't on right channel to show any programming what to do?
Hi William,
To confirm if the remote control is working fine, aim the infrared emitter of the remote control to your cellphone camera, press any button key and check if the infrared will flash to your camera. Watch this video on how to do this trick.
Also, does the front panel button key of the TV isn't working?
Jdvillanueva
Top QuantumFX Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a QuantumFX Televison and Video Expert? Answer questions, earn points and help others
