Kenmore White Electric Stove Logo
R
Ron Chapman Posted on Mar 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I get a stove door glass here
I need a replacment door glass
johnny rebel
Level 3:
Top Expert:
  • Kenmore Master 10,875 Answers
  • Posted on Mar 27, 2015
 johnny rebel
Kenmore Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2942296
Points
47944
I have black swirl scratches from using abrasive sponge on front of black oven door
There is this white stuff sold for glass-top stoves. I presume it is good old iron cleaner, a very mild cleaner/polish. Also consider toothpaste.
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
1helpful
I need a glass stove top for a kenmore mnodel
you can get them at sears parts direct, but they are most likely over $200 and it may take three or more tries to get a top that isn't chipped
Jul 16, 2009 • Cooktops
2answers
I need a new glass top for my stove that has shattered. Can you help me find one for a reasonable price? I have found many for $200.00 and Im thinking I should just buy a whole new stove for that price....
much better to buy a new one compare to replace it,coz its so very expensive or buy an electric hot plate more cheaper & practical compare to glass hob.
Jun 23, 2009 • Cooktops
2answers
Where can i find a replace glass top for a maytag performa stove
Hi, get ma a model # and I can get you part # and location of a glass.
Vic
Jun 06, 2009 • Cooktops
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
1helpful
2answers
Ceramic glass stove is cracked
HI
You should be able to replace the top only.
Normally if this is your fault, it is not covered by warranty. Normally this would be if you dropped something onto it. This would leave like a star shap series of cracks.
If its down to manufacture, this should be covered under warranty. This damage normally looks like just one long crack, no impact mark.
Check with the manufacturer
Rob
Feb 18, 2009 • Cooktops
Crack on glass top stove
Hello
Welcome to Fixya
My name is Huum,
You can replace the smooth top !.
But I will tell you not to spend more than half the price of a new stove. How old is the stove and what's the model number!
Waiting your response.
Please remember to leave a rating before you leave
7helpful
I cracked my Schott Ceran Cooktop glass
I located a company that supplies a new top but only to find that the tops are 400.00 anyway. I ended up purchasing a new stove to solve the problem.
Nov 18, 2008 • Cooktops
Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
Apr 07, 2008 • Cooktops
Top Kenmore Cooktops Experts
Kolbrun...
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
