After update from V171 to V1.76 the process loads until 100% then it shows update failed. Retried, but same issue again. So i shut down the TV but now it has NO function. I cant start my TV, standbly lamp is not bright. THOMSON 48FU4243C
SOURCE: TV Shuts off and on by itself
this problem has been seen and repaired at Sony from a bad lamp.Especially if lamp has lots of hours of use.Try a new lamp as see what happens.I have access to Sony docs and this is what I read..goodluck
SOURCE: TV GOES OUT AFTER 3 SECONDS.
There is a short in the set that is pulling down the power supply. You will have to send the set out to have it properly serviced.
Jerry G.
SOURCE: THOMSON SCENIUM 46"
You have not given the full model number or where abouts you are. Spares are available in the uk from [email protected] or call 01245392539 and have the correct info at hand.
SOURCE: I have HL-P5085 SAMSUNG TV that illustrates the
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem.
My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of
course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox,
Sony, Panasonic, and others were sold capacitors that failed in 2-5 years
instead of 10-20. The capacitors fail
prematurely due to a lack of preservatives. Unfortunately, they were installed in all
sorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is it
under warranty?) 2. Open your TV and find PSB. (The board that the power cord
plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps
replace the entire board. The entire
board costs around $250 right now because they are in high demand right now. They
can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourself
it will save you hundreds. I have a tip/tutorial
on this site that may also help. It
gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing
the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help
guide people though the process as well.
Let me know if I can do anything to help. Hope this helps and Good luck. Kaufman605
