Disconnect and reconnect the USB cable to ensure a secure connection
Press the POWER button to power on the printer
Select the correct port setting (Windows)
Set printer from Offline to Online
Set the default printer (Windows)
Try a different data cable
I have bolded the most likely problems. You did not specify your Operating System so it would be lengthy to describe how to check all of these. For detailed assistance , go to this webpage. In the Please Enter Your Question box, type ' Error: Off-line"; from the menu that opens you can access illustrated instructions for each of the above if necessary.
Trust this helps resolve your problem. Please vote.
These sound like unrelated problems. Uninstall the hard drive, and test if the printer light goes on.
Make sure the printer is connected properly, make sure the power cord is connected snuggly.
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above, 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal.
6A00 means the purge unit is stuck, it's the unit on the right that cleans the printhead. If you can see on the right, look for any paper scraps or things that don't belong. Otherwise it's a shop repair.
I have a pixma too, they are getting old, but as long as they still work who cares? Mine started to print green tinted pictures lately, now I'm searching boards and looking for the solution to that. I put in a service request to canon usa, but haven't heard from them yet, maybe never will. Long Live PIXMA's !
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
