Computers & Internet Logo
J
Jimoh Wasiu Posted on Mar 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i fix my Laptop PC which it CD ROM stopped reading CD ROM after i scanned the system with antivirus
The PC is running window 8
Harrie
Level 3:
Top Expert:
  • HP Master 6,746 Answers
  • Posted on Mar 25, 2015
 Harrie
HP Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285555
Points
83153
First switch of the laptop and then on again. If the error keeps comping back, then switch of again and remove the main memory for a few seconds. Most laptops, even after you switched off, keep the settings in their memory.
After moving, just place the memory back, close the laptop and try again.
Still no success after that? consult a tech.
Testimonial: "Thanks for assistance. I think I need to consult a tech."
  • Harrie Mar 30, 2015
    Did you try to put back another Windows 8 operating system? It will be difficult when you have your recover disk on a CD (DVD) but perhaps there is a recover partition on the HD and you can get back the driver.
3answers
Hi!! my pc laptop keeps on freezing,how can I fix it please?
Make sure it has the maximum memory installed. Also do a defrag. on your system.
2answers
MY Laptop Is Very Slow And Crash
* check you virtual memory or adjust it...
* scan your laptop with the latest update of anti-virus,might your laptop got many viruses.
hope this solution helps..... please rate my performance... thanks
5helpful
4answers
How to remove shortcut virus in my laptop
Run Norton Anti Virus to remove viruses.
2answers
Laptop hangs during anti-virus scan
which anti-virus do you use?
If it's McAfee, then it's quite usual. Leave it there for some time or skip the file.
I would recommend you to use Norton 360
Laptop: Toshiba Satellite NB200.Problems when restart after upadated antivirus (kaspersky 2010) this message appear: STOP:c0000221 [bad Image Checksum] The image urlmon.dll is possibly corrupt.the...
Yes it may be possible, installing and updating antivirus may have figured our corruption in urlmon.dll deleted the file or did some changes due to which you are getting the critical error
You can try 2 things,
1. Restore earlier settings, which may uninstall your antivirus and you need to install again. But if this works recommend you to first scan the system with free standalone antivirus availalable and then install your version of antivirus. Try following link
http://go.trendmicro.com/housecall7/HousecallLauncher.exe
http://www.trendmicro.com/ftp/products/rootkitbuster/RootkitBuster_2.80.1077.zip
2. Repair the URLMON.DLL file
1.Insert your Windows XP CD in your CD-ROM drive and boot your computer from the CD.
2.When the Welcome to Setup screen appears, press R to open the Recovery Console.
3.When prompted for an administrator password, type the password and then press Enter. In case no administrator password was set, just press Enter.
4.At the Command Prompt, type the following command and press Enter
cd %systemroot%\system32
5.Next, type the following command to rename the urlmon.dll file and press Enter.
ren urlmon.dll urlmon.old.dll
6.Now, to restore the original urlmon.dll, type the following command and press Enter.
expand [CD drive letter]:\i386\urlmon.dll %systemroot%\system32 /Y
7.Next, type exit and press Enter.
8.Restart your computer.
3. Repair complete OS. You will need XP CD
Boot from CD and follow the instructions to repair the OS
3answers
Just installed an antivirus on my laptop. since then when i insert a cd into the cd rom, the light blinks for a while, the cd rom makes a scrathy noise as if its finding it difficult to read the cd, the...
Dear,
Its not the issue with antivirus. By the by, which antyvirus you have installed. Have you tried by removing the antiviurs. If you feel the same after removing the same it is the issue with CD/DVD drive
2answers
Detects CD but not DVD
Hi Chopadepve,
Please try this method but be more careful during working out on it:
Since your DVD drive reads cd's, but not dvd's It shows that the hardware works fine. Now we need to Edit the Registry to fix this problem.
1) click the start menu
2) click on "run"
3) type "regedit" and click ok
4) go to string key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5) delete "upper filters" and "lower filters" in the right side window.
6) right click my computer in the start menu.
7) click properties
8) go to the hardware tab
9) click device manager
10) expand the dvd/cdrom drives
11) right click the dvd rom and click uninstall
12) Reboot PC
Windows should automatically install a clean ROM drive after the reboot otherwise Open the device manager window and click "scan for hardware changes". DVDs just read fine if you have the correct DVD decoders.
If no luck then might be DVD read head wiped out.
Regards
ELLIN
3answers
I have cd for norton antivirus 2008 need instructions on how to do it
1. Preparing before you begin
    1-1 Make sure that your computer has the necessary system requirements.
    * Windows XP Home Edition/Professional
    * Windows Vista (32 and 64-bit) Home basic, Home Premium, Ultimate, Business, Starter Edition
    * 300 MHz or higher processor
    * 256MB RAM
    * 180MB of available hard disk space
    1-2 Remove any other antivirus programs that you currently have installed.
    To remove them, click Start > Control Panel > Add or Remove programs. In the list of current installed programs, click other antivirus or firewall programs, and then click Remove.
    1-3 Make sure that you can connect to the Internet, then close that window.
    1-4 Close all open programs on your computer.
2. Installing and activating Norton AntiVirus
2-1 Do one of the following:
If you install from a CD, insert the CD into the CD-ROM drive.
If you downloaded your copy of Norton AntiVirus, double-click the file that you downloaded.
2-2 In the opening panel, click Install Norton AntiVirus.
2-3 Read the License Agreement, type your Product Key if prompted, and then click I Agree.
If you do not accept the License Agreement, you cannot continue the installation.
2-4 In the Installation Options panel, review the options, and then click Next.
2-5 In the Pre-Install Scan panel, click Start Scan.
The scan takes a few minutes.
2-6 In the Installation Confirmation panel, click Next.
2-7 In the Activation panel, wait for the progress bar to stop, and then click Next.
2-8 If the Norton Account panel appears, do one of the following:
* If you currently have a Norton account, complete the Sign in to an existing Norton Account section.
* If you want to create a new Norton Account, complete the Create a Norton Account section.
2-9 Click Next.
2-10 In the Norton AntiVirus Installation Complete panel, review your subscription details, and then click Finish.
2-11 In the Welcome to LiveUpdate panel, click Next to begin checking for the latest product updates.
2-12 On the next LiveUpdate panel, review the list of available updates, and then click Next to begin the updates.
This process takes a few minutes.
2-13 On the final LiveUpdate panel, click Finish.
A system scan begins automatically. When the scan is complete, the Norton AntiVirus main window opens.
1helpful
CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
