SOURCE: Hard Drive will not boot up - recovery cd set will
enter the bios change drive mode from AHCI to IDE
SOURCE: I have a problem where
The Best Solution is to format your laptop.. Upgrade it to the latest version as such Windows Vista or 7.. Then, upgrade your driver at your laptop service website.. www.acer.com
By the way, i think you should press f10 instead of alt+f10...
Good Luck...
SOURCE: My Acer Aspire One 150 netbook freezes even after OS re-install
Try formating your harddrive and reloading the OS. If that doesn't work you might need a new harddrive.
SOURCE: asusEee pc:everytime i turn on
Hi this is usually a corrupted driver usually a Video driver, but not always, it can sometimes be the harbinger of doom, and it may indicate that the HDD is going/gone? faulty.
Now what you may need to do is to perform a boot from a recovery CD/DVD or Boot from a Windows DVD, then either perform a system restore, or indeed a factory restore.
usually though, whenever there is a minor problem it will not continue to reboot as it is doing now.
In this case I think that you will have to attempt recovery from the USB port, please look at the link below, this will show you exactly what and how to do it all. You will need access to another PC to make the tools required to do the job.
http://myeeeguides.wordpress.com/2008/10/15/eee-pc-1000h-recovery-from-usb-flash-drive/
Another way below...
http://wiki.eeeuser.com/restore_1000h
