SOURCE: want to watch dvd without being parked
The easiest way to do this is buy a PAC-7 to wire in onto your brain. This item costs $20 bucks off of ebay. If you dont want to spend that you could get a toggle switch and wire that in because in order to get that to work you have to switch the toggle 3 time to get this to work. The Pac does the switching ineternally giving you a seamless view.
SOURCE: blue park screen . whats pink/black wire for? do i ground y/b wire and y/black wire
The pink/black wire is Mute input (e.g.: for Bluetooth interface)
SOURCE: I have a alpine cva1003 and cant get the screen
In order for the video to work you need to hook up both the parking and the foot brake leads so you would have to press in the foot brake pull the ebrake let up on the foot brake then the video should come up but if u want to watch videos all the time moving or stopped youll need to do some custom work so:
Short of making a microprocessor to do the sequence the easiest way is
the two switch method. just mount two switches together and do the sequence.
Although the idea of only one switch and the foot brake hooked up correctly might work too.
The best way to go about it is to hook up the system as is should be and
use a voltmeter to see what voltage changes are on the lines. Then
hook up the switches accordingly.
hope that helps!!
