I appreciate your post, Sharon!
From the information you have provided your Frigidaire side by side refrigerator is displaying an "H1" error code. I was unable to locate that error code but I did find the error code "HI" which stands for high temperature inside of your freezer compartment. Check your freezer is it still cooling? If so it may just be a miscommunication within your refrigerator and you can clear that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Best of luck! -Matt
Prior to finding this tutorial, I gave up looking for an explanation for the H1 Fault code, as I just couldnt seem to find it. Out of frustration, I simply unplugged it for about 5 minutes and plugged it back in. It went back to its previous setting of '5' and is still chugging away days later. Out of curiosity, I started searching the 'H1' again, using more specific terms and found this page
Sooooo, hope this helps.
