Question about Dyson DC59 Animal Bagless Cordless Stick Vacuum
I have cleaned the filter and it still stuttering
Cleaned the filter and I know it is filter as works fine without it in
  • Official Brand Answer
  • 2,572 Answers
Hi there, it's Jack at Dyson.
If you run your DC59 without the filter in place, this allows the airflow to enter into the motor through the top of the cyclone pack, bypassing the rest of the machine. It doesn't necessarily suggest there is an issue with the filter itself.
If you've recently washed the filter and your DC59 still pulses on and off when you pull the trigger, this suggests there is a blockage somewhere in the motorised floor tool, wand or bin inlet.
Please follow each of the steps shown in our Support video to locate and remove any obstructions. It's also a good idea to check that the bin inlet flap opens and closes freely.
I'm confident that removing any obstructions from your DC59 will restore normal performance. If you'd like any further advice from our experts once you've given this a try, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on Mar 24, 2015
  • mike hooper
    mike hooper Jun 02, 2015
    Had pulsing occur, followed above cleaning procedure and there was no blockage - looked into the suction inlet (where tools attach) and noticed there didn't appear to be any way for air to pass into the chamber ? i prodded the plastic in the tube and suddenly a plastic flat/trap door opened.
    I believe this should open and close freely, probably stops dirt and debree coming back out of machine when trigger released, but somehow mine had sort of glued itself stuck closed- may have been something sticky vacuumed up ??
    Anyway, just adding this in case it may be a design fault.
    Mike Hooper- paramedic, birmingham
  • AskDyson
    AskDyson Jun 02, 2015
    Hi Mike, thanks for getting in touch with this information. As you've mentioned, DC59's bin inlet flap should pivot open and closed freely. Dyson cordless vacuums have included similar inlet flaps to this since they were introduced in 2006, so it's not a design issue. However, if you notice any further problems please give us a call, so we can help with any issues affecting your particular machine. You can reach the freephone Dyson UK Helpline on 0800 298 0298.
6ya staff
SOURCE:
My dyson V6 keeps pulsing on and off
It could be the filters need cleaned or replaced. Try turning it on without the filters on it, if it doesn't pulse on and off it may mean the filters are restricted and need cleaned or replaced. Do not use the vacuum without filters.
Sep 17, 2017 | Dyson Vacuums
How do I get Bissell Proheat 2X to work. Not dispensing water.
Did you clean the filter on the water tank. It's generally a red screen type device. Additionally, there is a filter under the Flow Indicator, unscrew the cap, lift out the propeller, lift the filter screen and clean it. Reassemble in reverse order. If you occassionally run one and half cups of white vinager through the machine it will clean out the calc buildup. Additionally, the filters should be cleaned after each use.
Feb 07, 2016 | Bissell Brushroll Proheat 2X 8920 9200...
Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
Jan 11, 2010 | Euro-Pro UV209 Upright Vacuum
Cyclone will not spin
Even thought the belt may look fine the belt still can be worn and therefore no turn the brush or the clutch. The belts you need are these here:
DC07 with clutch belts
DC07 without clutch belts
Nov 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
Dirt devil purpose for pets vacuum quit working
The motor overheats from the filter being clogged underneath the canister or the canister or both are clogged-without the air flow the motor overheats and shuts off as a precautionary measure.By letting the motor cool off it will start again but will turn off shortly if the filters are not properly cleaned.Hope this helps everyone.
Rob
Oct 18, 2008 | Dirt Devil Purpose for Pets Portable...
Bosch vacuum Motor turns off after a few minutes
It sounds like you have a motor protection fuse that resets after an overheat/cooling cycle.These work the same as a circuit breaker in your house with the difference being they can reset themselves.The Bosch will also shut down if there is insufficient airflow and I would check your filters first.1) Pull the filter and let the machine run.Do not pick up debris when you operate without a filter-it will be drawn straight into the motor.If it runs fine without shutting down, all you need to do is change your filter.If it shuts down again check the external hose for any blockages.Also check the throat from the powerhead for any blockages.If you continue to have the same problem then you will need to replace the fuse because at this point you have eliminated all the other likely problems.Good Luck-Scott
Oct 08, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Vacum won't work
have you cleaned the filter?
Nov 03, 2007 | Dirt Devil M084600 Dynamite Bagless...
Dyson DC59 Animal Bagless Cordless Stick Vacuum Logo
784 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Gerry Harvey
Gerry Harvey
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
