JBL Flip Wireless Bluetooth Speaker Black Logo
K
Kevin Posted on Mar 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does it turn off after 10 minutes of use?
Paul Woodward
Level 2:
Sergeant:
  • Expert 200 Answers
  • Posted on May 19, 2015
Paul Woodward
Expert
Level 2:
Sergeant:
Answers
200
Questions
15
Helped
56513
Points
923
Maybe u havent charged its internal battery for long enough..
How to reprogram an ignion for a 1999 cavilier
to reset passlock system, The procedure is not to try to start the engine, but to leave ignition in ON position 10 minutes. Turn off and turn to ON for another 10 minutes, turn it off and turn to ON one more time for 10 more minutes.
This is a 30 minute procedure, not a 10 minute procedure. good-day !
I lost all power in a 2005 Trailblazer. Called GM and they said to kick the key forward and wait 10 min, and this would reset it. It did but now the radio A/C door locks and windows don't work. What...
Do it three times in a row.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
Here is a link about the security problem
http://vatspasslockpasskeysecurityhelp.yolasite.com/
1helpful
How to rekey a pontiac sunfire 2004
Im assuming you are refering to the anti theft security key relearn process.
If that doesnt work, look into this link http://vatspasslockpasskeysecurityhelp.yolasite.com/
2helpful
Programing a key fob
If this doesnt work, you may have a failure in your system. If the security light is on, and the reprogram doesnt work, you might want to look into bypassing that antitheft system.
How to reprogram key
If this doesnt work, and you are having STARTING issues, go to this link.
I need to program a new fob. am reusing the old key! can you help?
  1. Turn the ignition to ON, then wait 10 minutes for the next step in the programming sequence.
  2. After the 10 minutes has elapsed, the car horn will chirp once. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  3. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp twice. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  4. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp 3 times.
  5. Verify that the security indicator in the instrument cluster has stopped flashing and attempt to start the vehicle.
  6. Turn the ignition to OFF and remove the key from the ignition switch.
  7. Move approximately 3 meters (10 ft) away from the vehicle and test the transmitter functions to validate that the transmitter has been programmed successfully.
2helpful
This morning when I attempted to start my 2006 Hummer H3, nothing happened. I thought I may have a dead battery but the lights and radio work fine. I then noticed the Passlock security lock light was on...
Hello:Try this procedure: turn key on, turn to start, let key come back to on wait ten minutes, turn key off wait 10 seconds turn key back on wait 10 minutes. turn key off wait 10 seconds turn key back on wait 10 minutes turn key off wait 10 seconds NOW try and start. In addition you might try tapping on switch assembly while trying to start. There is not any way to disable passlock. You might try having the engine control system codes read
2helpful
I just put a new steering column in my 200 saturn sl2 because my ignition lock was messed up. Now when whe try to start the car, it will start up but immediately shut off and then the security light...
Hello: Will try to give you instructions: Attempt to start car, leave key on (security light flashing) let set for 10 minutes, After 10 minutes security light out. Turn key off for ten seconds, turn key on, let set for 10 minutes, turn key off for 10 seconds. turn key back on let set 10 minutes, turn key off for ten seconds, the engine should now start and stay running.
7helpful
Reset ANTI-THEFT DEVICE FOR OLDSMOBILE ALERO
Three cycles of ON-OFF:
Turn ignition ON, wait for 10 minutes.
Turn ignition OFF
Turn ignition OFF
Turn ignition OFF
Your system is reset and has been relaernt.
Hope this helps,
Please rate the solution,
Top JBL Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a JBL Radio Communication Expert? Answer questions, earn points and help others
