I am too short to use the foot board pedals on the organ because of a bad back and I just would like to turn off the sound to the pedals so I can rest my feet on them while playing.
SOURCE: I have a yamaha electone hs4, The foot pedals do not work.
JM: Your problem is this: There are rubber washerson the bolt that holds the pedal on. They are shot. Most likely Yamaha doesnot have the parts.Go to the plumbing dept of a hardware store and get some faucet washers and replace them. YYou can tell if the washers are shot by tiping over the organ and looking at the pivot bolt. Most likely that is yoiur problem. I am an organ tech. and have replaced many of these. DM
SOURCE: Lowery Tube Organ needs a tube
The "F" key contact is probably stuck on rather than a tube problem. It MAY be a mechanical thing OR it could even be contamination such as a staple or paper clip that has fallen into the key area. Look for something obvious around the key contact. Most any competent electronics person should be able to fix this one.
SOURCE: lowery organ works well but hums please help
Probably needs the filter capacitors in the power supply replaced.
The electrolytic caps dry out after years and become ineffective in filtering to get pure DC current for the electronics.
Other less likely possibility is a broken ground wire someplace within.
SOURCE: 1970's Lowery tube organ Very low
The problem is an accumulation of dirts inside the knobs, all you have to do is use a methylated spirit to clean the affected knobs. pour just little of the methylated spirit unto the knobs and then slide the knob up and down like 5 - 6 times and allow to dry for some minutes.
With this your appliance is ready for use again.
Hope this helps......
SOURCE: manual and playing instruction for Lowery MX2
You can download the manual here
Hope it helps.Thanks!
