please ensure that the power outlet in your new home is providing energy with the same voltage and current that your old house provided. This might not be the case if you moved to a different country. You would need to find an adapter to adjust the voltage and current. If this is not the case, then you might need to reach out to your manufacturer to ask them to recommend the closest repair technician to your location.
I have only subwooper biult in Amperfire - philps home threatre WS5500C - 98 old model, but I have no the DVD it self. I mean the control or other part anywhere Iwant it to work as amplifier only Can you help.
After a move and something doesn't work that could have before, it's always best to check inside for signs of damage. It might just be a bad soldering joint, so it could be just a small amount of damage.
Yes. Most if not all speakers have impedances which vary with frequency and are rated at a nominal or average impedance. So a manufacturer who rates their speakers at 6 ohms may be more honest or chooses to quote it at a specific frequency. So a nominal 8 ohm speaker may actually measure 4 ohms at 100Hz and 12 ohms at 500Hz but averages somewhere nearer 8 ohms. It is normal for most speaker manufacturers to simplify their ratings so speakers which average at say 6 ohms would be categorised as 8 ohm, and 4.9 ohm averaged speakers as 4 ohms.
As a point of interest - some amplifiers are specified as providing their maximum power at impedances of 6 ohms, and there fore some speaker makers (including those made by same manufacurer as amplifier) will rate their speakers at 6 ohms so they appear more compatible.
I would strongly recommend that you get a 5 channel amp that puts out 75watts rms per channel that will deliver between 200-300 watts to the sub channel. I use planet audio amps myself and they run strong all day every day-maybe you could look at a planet audio vrx 600.5(5-channel) it throws 100w x4 and 200 or 300 to the subs depending on the resistance of the sub. Good luck
sir check your power cable and on off switch in back side of woofer next see audio out cable pc to woffer cable and drivers also ok if any Problam contact :- hardware eng ok by
