Targus Screen Protector Samsung Galax - AWV1229US Logo
Rashell Broome Posted on Mar 21, 2015
My galaxy s is stuck on the Downloading...do not turn off target!!!" screen I have tried takeing out the batterie and volume up home and power neither one worked
Model SGH-1897
Galaxy 7 edge black screen, won't turn on ?
Try taking the battery out. Then put battery back in. Before turning on hold the volume up button, home button and power button at the same time. When the android screen come on let go of the power button and press the volume down key and follow the on screen instructions.
I have a problem with my galaxy note3,i did factory reset and then rebooting system,just the galaxynote3 appears on the screen ,nothing change again
  • Remove the battery and the SD card.
  • Put the battery back in and turn on the device.
  • Try Menu > Settings > Wi-Fi > Menu > Advanced and uncheck Always allow scanning.
  • Now you should be able to turn the device off and reinsert the SD card.
  • Boot it up and your problem might be gone.
    • Also try this if the above mentioned doesnt work
    • You could remove the SD card, backup the data, put it back in the phone and try reformatting it via Settings > Storage > Format SD card .
    • If it's stuck in a boot loop and you can't get in to the main menu, you could factory reset the Galaxy Note 3 using the hardware buttons (but you will lose all data on it). Back up first if you can, and then:
    1. Turn off the device.
    2. Press and hold the Volume up, Home, and Power buttons.
    3. When you see the Galaxy Note 3 logo, let go of Power.
    4. When you see the Android System Recovery screen let go of Volume up and Home.
    5. Press Volume down to highlight wipe data / factory reset.
    6. Press Power to select it.
    7. Press Volume down to highlight delete all user data.
    8. Press Power to select it and wait until it's done.
    9. Highlight reboot system now and select it with Power and your device will reboot.
    Read more: http://www.digitaltrends.com/mobile/galaxy-note-3-problems/9/#ixzz3LPBRtSme
    Follow us: @digitaltrends on Twitter ' digitaltrendsftw on Facebook
    Read more: http://www.digitaltrends.com/mobile/galaxy-note-3-problems/9/#ixzz3LPBHTGRq
    Dec 09, 2014 • Cell Phones
    Galaxy ace won't go past start up screens
    Stuck in bootloop. Do a battery pull, let it sit, reinsert and try again. If that doesn't work you can attempt to do a factory reset by holding volume up, home button, and then pressing power. It should take you into download mode and there is an option to reset or restore to default. **DISCLAIMER** If you do this you will lose ALL DATA on the PHONE! Use this at your own discretion.
    2answers
    How do i reset my samsung galaxy 3 if it wont come on?
    1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
    2. Hold the Volume Down button
    3. Briefly Press and release the Power button
    4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
    5. Select Clear Storage by pressing the Volume Down button
    6. Quickly Press and release the Power button
    7. Select Volume Up for YES and Volume Down for NO
    If the above procedures doesn't work. try this another method:
    1. Turn the POWER OFF, pull the battery out and put it back again.
    2. Simultaneously press the Volume Up, Home and Power button
    3. If the Samsung Symbol appears, release the Power button
    4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
    Galaxy s3 won't turn on fully
    Hello Sarah,
    You can try these solutions:
    Solution 1: Soft Reset(no data loss)
    1. Take out the battery and leave it there for 5 minutes.
    2. Reinsert the battery.
    3. Press and hold the power button for 10 seconds.
    Solution 2: Replace Battery
    1. Take out your battery
    2. Insert new battery that you found from a friend or family with same model.
    3. Power on
    4. If it works,buy a new battery
    Solution 3: Hard Reset(you will loose your data)
    1. Switch off the device.
    2. Press and hold Volume Up + Home Button + Power Key.After 2-3 seconds, release the Power Key.
    3. You will enter boot screen,use volume buttons to navigate and select Select Wipe Data / Factory Reset and then press power key.
    4. Select Yes.
    5. Reboot your device and wait to power on.
    If nothing works you have to take it to your supplier.
    I have a samsung galxaxy player 4.0 and it says downloading do not turn off target, i cant take it off or taking out the battery dosent work either it just shows the same screen! Help? Please...
    try doing this:
    Volume Down + Home + Power at the same time during power up. This will put it officially in download mode. When "Downloading..." is again displayed take out the battery, wait 30 seconds and reinsert it (don't connect the charger or any cables)
    Let me know what happens..
    Nov 11, 2013 • Cell Phones
    My samsung galaxy s 4g will turn on but then just vibrates with a blank screen. I tried to reset it with volume down+ power but the reset menu doesn't come up
    do this to wipe partition cache
    1. Turn off the phone
    2. Note: If the phone will not power down, remove the battery and reinsert it.
    3. Hold the Volume Up, Volume Down and Power Key simultaneously.
    4. Release the keys when the Android recovery screen appears.
    5. Press the Volume Down key to highlight Wipe Cache Partition.
    6. Press the Power key or Home key (this varies based on the software version of your phone) to select.
    7. The phone will display Cache Wipe Complete after a few seconds.
    8. Press the volume keys to highlight Reboot System Now.
    9. Press the Power key to select.
    i advise you to back up everything first before doing master reset
    1helpful
    2answers
    My Samsung will not turn on. The big s stays on the screen and every minute it vibrate. The home and back button also light up
    SAMSUNG GT-I9000 GALAXY S [ HARD RESET ] FORMAT FORGETTON PATTREN SOLUTION [ TESTED ]
    [1] Take out & Insert battery
    press & Hold VOLUME up+ Home Button
    Keep Power Button Pressed for 4 Seconds[important]
    Still KEEP Volume up & Home Button Pressed
    [2] Phone will Start In RECOVERY MODE
    scroll down using volume down button to " wipe data/factory reset"
    [3] press Home button to select
    now scroll to "yes Delete All user Data" to confirm
    [4] press Home Button.
    Your are Done.
    [IMPORTANT]
    Make sure you will loose all data Saved on phone memory like photos & Phone book videos ETC.
    Top Targus Computers & Internet Experts
    Paul Bade
    ADMIN Andrew
    ADMIN Andrew
    Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
