VESA Specifications
VESA STANDARD
HOLE PATTERN
SCREW SIZE
MONITOR WEIGHT
SCREEN SIZE
FDMI MIS-B
50 x 20 mm
M4 x 6 mm
? 4.4 lbs / ? 2 kg
4" to 7.9"
FDMI MIS-C
75 x 35 mm
M4 x 8 mm
? 10 lbs / ? 4.5 kg
8" to 11.9"
FDMI MIS-D
75 x 75 or 100 x 100 mm
M4 x 10 mm
? 30.8 lbs / ? 14 kg
12" to 23.9"
FDMI MIS-E
200 x 100 mm
M4 x 10 mm
? 50 lbs / ? 23.7 kg
24" to 30.9"
FDMI MIS-F
200 mm increments
M6 x 8 mm or 10 mm;
M8 x 15 mm
? 250 lbs / ? 113.6 kg
If you decide to wall mount your LCD TV, always use a ULlisted
wall bracket appropriate for the size and weight of the
LCD TV:
32HL37/32HL37U/32HL17/32HL17U:
38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component
connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket.
Before proceeding, make sure the appropriate bracket(s) are
attached to the wall and the back of the TV as described in the
instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the
back of the TV, remove the pedestal stand from the TV as
described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
There should be two rectangular holes about 2mm wide and 10-12mm long. There is a wall mount bracket [D470] which you install against the wall and then the hardest part is getting the dryer on the bracket.
Obviously when installing the bracket make sure that the wall and the screws can hold at least 30kgs.
