GE Profile Spacemaker XL 1800 36" Microwave Oven Logo
J
Jack Talley Posted on Mar 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set the power at 50%? - GE Profile Spacemaker XL 1800 36" Microwave Oven
Jerry Smith
Level 3:
  • GE Master 473 Answers
  • Posted on Apr 05, 2015
Jerry Smith
GE Master
Level 3:
Answers
473
Questions
0
Helped
145265
Points
1230
After first setting the cook time---then hit the power level button and hit the number 5 (for 50%) and then start. Power level can also be changed while running by hitting power level button and selecting 1 through 10. For example level 3 is 30% for defrosting.
How do i change the power setting on a Sharp carousel microwave
Which model of Sharp microwave do you have?
For the SMC1441CB, after setting the cook time, press the power level button and then the appropriate digits for the percentage of full power to use. For full power, press power level then 1 and then 0. For 50% power, press power level then press 5.
For the SMC0710BB, after setting the cook time, press the Power button until you see the desired power level displayed on the LCD screen. Press Power once to get 100% power. Press Power 6 times to get 50% power.
For the R-659YW, you set the power before setting the cooking time. You press the Power button several times to get to the desired power level. Pressing Power 7 times will have the microwave cook with 40% of its full power level.
Many current Sharp appliance manuals are available on their product page or the Sharp support page. The current Sharp microwaves are listed here: http://www.sharpusa.com/ForHome/HomeAppliances/Microwaves/Models.aspx?facet:configurationfilter=Countertop . Other appliance manuals are available when you enter the model number in the search bar at http://www.sharpusa.com/Support.aspx .
I hope this helps.
If I want to cook a microwave dinner that cooks for 9 minutes @ 50 percent power how do I do this?
Cut the time in half if your machine doesn't have the setting for 50% power.
How do you change the power setting
push 12.00 (or whatever minutes you need) then power then 50 for 50 % 60 for 60% etc
1helpful
How to set at 50% power?
Hit power, hit 5 all after u set cook time.
2helpful
How to set power settings
Set the time as you normally would to cook your food: i.e. 60 seconds. Hit the power button; 100 will pop up on the screen, as in 100 % of power, enter 50 for 50% power, 70 for 70% etc. Food will cook more evenly this way, not burnt to a crisp on the outside, cold in the center.
Power Setting
It depends on the brand and model, but usually it's something like:
Cook Time > 2 > 0 > 0 > Power > 4 > Start, where 4 is 40%, 5 is 50%, etc.
2helpful
I do not have the manual. How do I change the poiwer level on a Frigidaire Microwave model FMT116E1W
After setting the time amount before you hit the start button, push the power button with each push it should indicate a different power level if not you've got to use the keypad, for example, 50 is 50% power etc.
2helpful
How do you set whirlpool microwave to 50% power
The microwave oven should be at a temperature above 50°F (10°C) ... microwave oven can be manually set to defrost. To defrost. manually, use 30% cook power. ...
www.whirlpool.com/assets/pdfs/product/ZUSECARE/8205987.pdf
8helpful
Howm do I reduce power down to 50%
First enter the cooking time just like normal, but then you hit the power button and then hit the digit indicating the power level you want. THEN hit start and it will start cooking.
5helpful
2answers
How do I set the power to 50%?
If you have "Power" botton on m/w
1. set time for time cook
2. press power botton
3.set 50 and hit start
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
