Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
Chain turns but will not cut wood - Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
  • 76 Answers
The chain is probably dull , you need to sharpen it.
In order to prevent it from going dull again you should always check that there is enough chian oil and avoid the chain touching sand or dirt while sawing .
Posted on Jul 15, 2009
  • 33 Answers
Chain is on backwards or very dull.
Posted on Jul 09, 2009
6ya staff
SOURCE:
When go to cut engine is runnig but chain stops when touch the tree
Hi Pam:
Using chain saws takes a bit of getting used to, and it can be DANGEROUS.
- The chain must be sharp to be able to cut properly, and a sharp chain "bites" into the wood.
- Before you touch the chain into the wood, you have to speed up the engine. This takes some getting used to.
- Try this technique: With the chain about an inch above where you want to cut, squeeze the throttle about half way so the chain is spinning. Touch the chain to the wood and increase the engine speed as the chain starts to cut. The harder you cut, the more power you need to apply.
After a while it gets to be second nature.
Work Safe, and get an experienced friend to help with some "hands on" coaching.
Cheers.
Nov 26, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
After using anew chaini hit dirt. isharpenit withadifferntanglewillthat make a differencein cutting.
sure will , most saws have different angle cuts to teeth on blade this "angle" needs to be maintained as the "rake" teeth that are behind the cut teeth are set to provide a good way to wipe out cut debris (cut,rake,cut,etc.) this is how chain cuts thru wood , if one changes the cut angle on teeth the rake teeth might not do there job correct and saw bogs and "files" thru wood rather than chips thru wood ,takes longer ,more fuel, more effort , a look at saw cuttings tells the tale , more tiny file sawdust = dull chain --- large Chips and less dust = sharp chain
Aug 26, 2015 | Garden
What would cause a new chain saw not to cut
Maybe I'm reading this wrong, but it sounds like you are saying your chainsaw is newer and runs fine, but it just isn't cutting wood well?
If that is the case then it means the chain wasn't sharpened correctly. Lots of guys do it at home and don't file down the raker teeth in front of the cutter heads, so the teeth don't grab into the wood and just nibble at the wood and make fine sawdust. It is always best to get the chain sharpened at a saw shop first so you can get an idea of the correct angles and depth of the rakers etc. After that you can try to match the saw shop for a while with a round file to take off ragged edges unless you have a decent professional saw sharpening unit.
Nov 03, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
New Homelite. Cut great for an hour, then the chain wouldn't grip or cut. Chain was loose so I tightened but still doesn't cut- just
The blade is no longer sharp, something not unusual after about an hour of cutting. How long a blade stays sharp depends on what type of wood you're cutting, whether the blade contacted the ground or anything other than wood at any time, and how hard you are working the bar through the wood. If you are cutting hardwood or something like railroad ties the lifespan of the blade is greatly reduced. You can easily sharpen the blade with a hand file or dremel tool with a chain saw blade kit on it or have the blade sharpened. Best practice is to have one or two extra blades so you can change them as they become dull.
Mar 29, 2012 | Homelite Garden
I have a efco 165 chainsaw and for no reason i will be cutting good clean wood and it will just go dull. there's no cut marks inside like it hit metal. it has been doing it since it was new.
It seems like they supplied the machine with an inferior standard chain, replace the chain with a good brand and see if that solves the problem. (Chain saws are not too fond of cutting dry wood, they do far better in wet, green wood).
Apr 04, 2011 | Garden
My bosch ake 35s isn't cutting, what's wrong with it? chain turning as normal
Chain has dulled. Needs sharpening.
Hitting one little imbedded rock in the wood and the chain can be dulled to the point it only burns the wood.
Replace the chain or have it sharpened.
Apr 12, 2010 | Bosch Garden
I cut mostly hard woods, oak, hickory etc. I just
Have the chain professionally sharpened (Stihl or Husqvarna) at a saw retailer (take your saw). While there ask them to verify the gauge of the bar and chain are the same. When you return to pick-up your chain bring a few pieces of wood. Ask them to make a few cookies with your saw. Please reply with the result.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 28, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
CHAIN SAW QUITS CUTTING AS IT HITS WOOD.
The make, model, and occationally the serial number help us solve your problem.
Does the engine quit running? (Carburator needs adjustment)
Or does it continue running and chain stops? (need clutch refaced or replaced.) (to aggressive a chain for the size of the engine)
I think you replaced parts unnecessarily. Maybe quicker and cheaper to visit your friendly neighborhood chainsaw shop. A good one can repair it even if they do not sell your brand.
HTH
Lou
Sep 09, 2009 | Homelite Garden
Saw will not cut , chain stops turning when chain touches wood
If your saw has a removable sprocket, Check the drive sprocket on the clutch drum. Either the the spline is worn or the drive link on the chain is not properly seated in the sprocket well.
Apr 09, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Wood is smoking
this is usually from a dull chain
Oct 16, 2008 | Black & Decker CCS818 Chain Saw
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
119 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
