Right Triangle ABC has vertices A-4 2 B-4 6 C9 6
The area of a triangle is 1/2 times base times height. A sketch of the triangle in the coordinate plane will determine how easy or hard this will be to be. From the sketch, you will see that this is a right-angled triangle with B being the right-angle. This makes it easier because we can easily determine the base and the height to use in the formula.
We can chose AB or BC to be the base, while the other will be the height. If we choose the base of AB, its length is 4, the 6 - 2. The height is 9-(-4) or 13.
We can now put the length and height into the formula to calculate the area of the triangle.
Good luck.
Paul
