Washing Machines Logo
P
Peter Finch Posted on Mar 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix a Sears washer 110-20922991 that takes forever to get thru a cycle?
Set for the 10 min Perm Press cycle. Agitator moves for 2 or 3 rotations then stops for 10 mins or more. So far gone from 10 - 4 mins but took over an hour to do so.
robert
Level 3:
  • Washing Mach... Master 2,548 Answers
  • Posted on Mar 21, 2015
robert
Level 3:
Answers
2548
Questions
0
Helped
870545
Points
8043
Mechanical timer. Replace.
  • Peter Finch
    Peter Finch Mar 21, 2015
    Will do, Thanks
Slow agitator
Sometimes it is a very simple fix.
Agitator dogs.
4 little plastic thingies that wear out so the agitator has nothing to grip.
I'm not sure if they are specific to each model washer but it's about a $5.00 try.
You have to take the agitator out.
I watched YouTube.
Pretty easy and far less expensive than a pro!!
It took 10 mins. The hardest part was getting the agitator apart, which takes elbow grease!!
1helpful
I have an older Kenmore top loading washer model 11082994100. The machine is in excellent condition and I replaced the main control board a couple of years back. Issue is lately when machine goes to end of...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082994100/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (16 oz. of oil in the transmission) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
1helpful
2answers
Agitator: bottom moves, top does not
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
1helpful
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Agitator not working properly
if the agitator barely moves, sounds as if yo have a bad set of agitator dogs, part number 80040. if you removeth agitaotr,(7/16 screw) down the center ofthe shaft. yo can removeth efabric softener dispensor by hitting with the palm of hand. after removing the agitator, it can be split in half to reveal hte "agitator dogs" easy repair problalbby about $20 and 30 min tops
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Top Washing Machines Experts
john h
