Re: i need to tighten the tensioner on my 220 bayou
You dont have to take either side off it has a built in adjuster it is self tighting and round on the back of the engine has a ten mm bolt in it if your getting a tapping sound you need to adjust your vavles
The larger idler gear ring was spinning but not spinning the entire gear. I couldn't figure ... Starter Idle Gear Limiter Kawasaki Bayou 220 250 39076 1060 ' eBay ... kawasaki bayou 300 starter will not engage.
www.cyclepedia.com/...manuals/kawasaki...manuals/kawasaki-klf250-ba... The Kawasaki KLF220/250 Bayou requires the valve clearance, engine oil and oil filter be inspected every 600 miles. Keep your Bayou free of problems and in ..
Maybe time for a clutch rebuild. Loosen nut on right cover, hold in place, run screwdriver slotted bolt in until it seats then back it out 1/2 turn, hold screw in place and tighten the nut!
When you filled with new oil, if you changed the oil filter, and the oil was at the top third of the inspection window after you started it and then shut it off, the oil level is correct. When you start the engine the oil is being pumped to the top of the engine and through all of the oil passages. That is why you can not see oil in the inspection window while it is running. Make sure when you are checking the oil through the inspection window the vehicle is on a level surface and you have allowed enough time for all of the oil to drain back to the crankcase.
