see this causes and fix it. God bless you
Open Lever
If the microwave door won't open the open
lever might be broken. This part can be replaced separately.
Door Spring
If the microwave door won't open the door
spring may have broken. The door spring is located inside the door and
keeps downward pressure on the door hook.
Door Latch
latch might be broken. The door latch is inside the microwave. The door
hook, which is part of the door, engages with the latch to keep the door
closed during operation. If the door latch or actuator breaks the door
may not open.
Door Hook
hook might not be releasing properly. The door hook is installed inside
the door and normally releases when the door is opened. The hook is made
of plastic and will break over time. When this happens it will need to
be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button
spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle
actuator might be broken. This is a plastic part which can become
brittle over time. This part is connected between the door button and
the door latch assembly.
