It sounds like a fuel issue. Drain all fuel. Clean out tank and carb. Use aerosol carb cleaner. The pickup hose may need to be cleaned out as well.
Remove all fuel from tank and check fuel filter in tank if a lot of trash is found in tank clean tank with carb. Cleaner by spraying and sloshing and pour out and do again until all trash is removed. Then blow out thoroughly with compressed air.
SOURCE: AC blower motor
i had the same problem on my 2002 Axiom, I took it to the dealer and they said the blower motor is going out. They replaced it with a new one and it works fine now!
SOURCE: troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
SOURCE: blower motor resistor
The blower motor resistor is located near the blower motor. It is held in place by 2 screws, and has a wire clip connected to it. Very simple fix.
I hope this helps you, and I wish you luck on your repair.
SOURCE: Blower motor runs somethimes
Could be a faulty switch, or wire connector problem, and not necessarily the blower motor. You could save yourself $600 by doing a little troubleshooting to find the problem.
Try wiggling the wire connector at the blower and the switch. If it is the blower motor, spend a few dollars for a chilton's manual or haynes, and do it yourself.
Testimonial: "Thanks for the quick response. I will try what you suggested."
SOURCE: husqvarna k750 runs for about 5 mins then shuts
Obevisley is over heating make sure all fins and vents are clear and blown out then the only other thing is to replace the ignition modual just trace the plug wire back to flywheel and ignition block
Not chainsaw ! Torpedo heater
