SOURCE: Replacement of the thermostat in my 2003 Mercury Grand Marquis
yes you can,drain coolant from the radiator,remove radiator hose,detach the thermostat cover from engine , remove the thermostat noting the direction in which it was installed in block. remove the gasket and thoroughly clean the sealing surface , refit the therostat.rifitting is the reverse of removal.
SOURCE: rear shocks on a 1996 Mercury Grand Marquis
2 bolts on the top of shocks and 1 bolt on the bottom but the top 2 bolts are a pain in the neck
SOURCE: 1988 3.8 olds cutlass Ciera stalls, no spark until it cools down
Check the prrimary and secondary resistance on your coil. Also check the resistance of the plug wires and plug gap.
SOURCE: how to replace starter +1993 Mercury Grand Marquis
disconnect battery,,jack car up,,put jack stand on frame,,take starter bolts out,(may not be easy),,take wires off starter,,hoped it helped,,
SOURCE: 2005 MERCURY GRAND MARQUIS GS LCM headlights
you can oder a cheap lcm from silverstatefordparts.com or sometimes u can just tap the lcm box and lights should turn back on.
