Miscellaneous Logo
glenn brown Posted on Mar 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i get my transmission to shift correctly ? Should i put the old pcm back in my car ? Reset pcm thru dealership ?
After replacing my PCM on my 2004 3.4 liter chevy impala I drove the car for 1 day and now I'm getting a trouble code of 1810 . Why is the newer PCM giving this trouble code and my old PCM never did ? Now my car is stalling out at lights and stop signs . Now the car seems be be stuck in 2nd gear as I'm accelerating over 45 mph . />
Francis Mestayer
Level 2:
New Friend:
  • Expert 80 Answers
  • Posted on Mar 17, 2015
Francis Mestayer
Expert
Level 2:
New Friend:
Answers
80
Questions
Helped
35460
Points
231
My first question is: Why did you change your PCM in the first place, I would try the old one back in as soon as possible. And the old PCM may have to go thru a learning cycle before it works correctly.
  • glenn brown Mar 17, 2015
    I had a mechanic scan my car and he said my PCM is bad . I originally had a trouble code that said my egr valve was closed . I replaced that egr valve and still got the same code afterwards .
2005 chevy malibu damage Light front end damcodend error codes P0401 P0605 P0842 P0642 The 0401 code is being thrown twice and I belive it is the egr wich is common on these cars from what my buddy tells...
DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
Probably plugged passage's , not the EGR valve .
What type code reader are you using to read these codes ? I have factory service info. Doesn't show P0842 or P0642 , no such codes . You don't show what engine yours has , I'am assuming you have 3.5 L !
P0604
Control Module Random Access Memory (RAM)
PCM
DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610 in Engine Controls - 2.2L (L61)
or
DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610 in Engine Controls - 3.5L (LX9)
P0717
Input Speed Sensor Circuit Low Voltage
PCM
DTC P0717 in Automatic Transaxle - 4T40-E/4T45-E
P0741
Torque Converter Clutch (TCC) System - Stuck Off
PCM
DTC P0741 in Automatic Transaxle - 4T40-E/4T45-E
P0742
Torque Converter Clutch (TCC) System - Stuck On
PCM
DTC P0742 in Automatic Transmission - 4T40-E/4T45-E
P0748
Pressure Control (PC) Solenoid Control Circuit
PCM
DTC P0748 in Automatic Transmission - 4T40-E/4T45-E
P0751
1-2 Shift Solenoid (SS) Valve Performance - No First or Fourth Gear
PCM
DTC P0751 in Automatic Transmission - 4T40-E/4T45-E
P0752
1-2 Shift Solenoid (SS) Valve Performance - No Second or Third Gear
PCM
DTC P0752 in Automatic Transmission - 4T40-E/4T45-E
P0753
1-2 Shift Solenoid (SS) Control Circuit
PCM
DTC P0753 in Automatic Transmission - 4T40-E/4T45-E
P0756
2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear
PCM
DTC P0756 in Automatic Transmission - 4T40-E/4T45-E
P0757
2-3 Shift Solenoid (SS) Valve Performance - No Third or Fourth Gear
PCM
DTC P0757 in Automatic Transmission - 4T40-E/4T45-E
P0758
2-3 Shift Solenoid (SS) Control Circuit
PCM
DTC P0758 in Automatic Transmission - 4T40-E/4T45-E
P0815
Upshift Switch Circuit
PCM
DTC P0815 in Automatic Transmission - 4T40-E/4T45-E
P0816
Downshift Switch Circuit
PCM
DTC P0816 in Automatic Transmission - 4T40-E/4T45-E
P0826
Up and Down Shift Switch Circuit
PCM
DTC P0826 in Automatic Transmission - 4T40-E/4T45-E
P0973
1-2 Shift Solenoid (SS) Control Circuit Low Voltage
PCM
DTC P0973 in Automatic Transmission - 4T40-E/4T45-E
P0974
1-2 Shift Solenoid (SS) Control Circuit High Voltage
PCM
DTC P0974 in Automatic Transmission - 4T40-E/4T45-E
P0976
2-3 Shift Solenoid (SS) Control Circuit Low Voltage
PCM
DTC P0976 in Automatic Transmission - 4T40-E/4T45-E
P0977
2-3 Shift Solenoid (SS) Control Circuit High Voltage
PCM
DTC P0977 in Automatic Transmission - 4T40-E/4T45-E
Sometimes with code readers they get confused an just throw any old codes . Have it checked by someone with GM Tech 2 scan tool .
'01 Grand Caravan 120,000 miles. Frequent but intermitente problem: When in drive, gear indicator shows "D" put it in Park, feel it shift but indicator still says "D" shift it into Reverse, shifts and...
Did they change the BCM or PCM? The BCM doesn't have anything to do with the gauges or transmission shifting or the PRNDL lights. The transmission range sensor is where I would start. This sends a signal to the PCM, from the PCM to the PRNDL lights. The PCM also reads other sensor for shifting. I would have to put it on a scanner to see what was going on. Three things I would definitely check are the range sensor, wires from the range sensor to the PCM and the PCM.
The dodge dealership said we needed a pcm, so we replaced it. Now, the transmission wont shift out of low gear. The pcm has 3 missing pins. Will this effect the transmission? I'm thinking we need to get a...
did the original pcm have thee missing pin, they may not be missing they may be left out in engineering, as far as the trans not shifting, was the pcm reprogramed because if you just installed out of a box it unlikly that it will shift
1helpful
2answers
I have a 2005 PT Cruiser and the engine light came on and won't go off... Now the transmission won't change out of first gear...I had the the thraddle positio sensor replaced and then I was sent to a...
Not shifting out of 1st (probably 2nd gear) is called "limp home" mode designed to prevent further trans damage from a mechanical or electronic failure. While the problem could be ecm/pcm related, that is very unlikely. Getting someone other than a dealer to try to diagnose the problem is very risky. If a dealer tells you what is wrong and gives an estimate to fix it, he then owns the problem. This will likely save you grief and money in the long run.
Resetting transmission codes 2005 dodge1500 truck
make sure you have VSS SENSOR ELECTRICAL CONNECTOR CONNECTED, AND ITS NOT UNCONNECTED.more likely the dealership has to reprogram new transmission to the TCM PCM so transmission will shift correctly.
Pcm changed and now transmission wont shift
you might have to take your dodge to the dealership so they can flash the computer.... call them and ask.....
How is Transmission adaptation on 03 Passat done?
TRANSMISSION HAS TO BE REPROGRAMMED IF NEW ELECTRONIC PARTS PUT IN OR YOU BUY A NEW TRANSMISSION.BECAUSE TRANSMISSION IS PCM AND TCM CONTROLLED NEW PARTS HAS TO BE REPROGRAMMED TO THE PCM AND TCM BEFORE TRANSMISSION WILL SHIFT CORRECT.
1helpful
I own a 2004 Ford Freestar Van. I started the van one morning to go to work and put the van in gear and it would not move. I have never had any issue with the van. It only has 77K miles on it. Could it...
Hello! There is a Technical Service Bulletin; TSB 06-14-10 for this vehicle that addresses water entering the Power Train Control Module (PCM...computer) or Transaxle vent which will cause transmission problems...A fix for this problem is available at your dealership...Your vehicle does have an electronic shift transmission...Which is controlled by the PCM...No individual fuse powers the digital shift circuit...It powers the PCM...If a fuse were blown the vehicle would not start...
Guru......Saailer
Iā€™m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
1helpful
2002 Dodge Grand Caravan I just put a master computer on. Is there a way that I can reset it? The engine runs fine so I know it works but it wont shift properly.
Hope you put a PCM in. TCM is in side the PCM. The TCM sometimes needs a brake in period. 200 miles. If not call the dealer to have then flash the PCM with the updates. Around $80 at the dealer. Tell them you want to FLASH to PCM for bump shifting. Any Chrysler, Jeep or Dodge dealer can do this in 1 hour. Thers a Chrysler TSB #2101807 Dated 10-27-07 about Transmission Reprogramming. If the dealer put the PCM take it back tell them about the TSB
Have a 94 gmc 1500 4.3 automatic when i put it in drive it doesn't shift if i manuely shift from first to drive it will shift it doesn't have any slipping it also has overdrive that doesnt seem to work any...
Transmission does not shift automatically, only manually. Swap in a known-good PCM, check wiring, check other sensors such as VSS and TPS.
Trans shifts into gear harshly, car feels sluggish off the line
, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmision is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the underhood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Good luck and get back to me, hope this helps.
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
