A horizontal band of thin green and red vertical lines, about 2" tall, has appeared across the top of the screen. The band alternates between about 15 green lines, then 15 red, then 15 green, etc. When it the TV is first turned on it's not visible, but gradually phases in after about 2 minutes. When the image on that area of the screen is white, the band of lines isn't visible. Any ideas what the problem is, and how much it might cost to repair it? Thanks.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
