GE JVM1860 Microwave Oven Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My jvm1860sd001 model is not heating up - GE JVM1860 Microwave Oven
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Jul 09, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2972463
Points
24702
Check the following before you replace the Magnetron device.
1. Check the diode located inside the unit on the noise filter board assembly. it may be damaged.
2. Check the Magnetron Cut-Off Fuse. this will shut off the heating device if there is a fan issue.
3. Check the H.V. Capacitor for burn marks and, discolored terminal points. this will be a sign of a malfunctioning Capacitor device. replace if needed.
If all is ok with the above check list, replace the Magnetron tube.
  • g_goelzer Sep 24, 2011
    How can I test the diode? I have a digital volt/ohm meter.
Installation Template for spacemaker xl1800
It *may* be included in new installation instructions if they are still available, or you may have to order them if they are still available.
You can enter your full model number (something like "JVM1860SD001" for example) here and find out the part number, then you can order GE parts at a good price from the Pros here.
For more free DIY and other help & advice, feel free to contact me via my site below.
Please include FULL model number*, FCC ID number*, and detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
1helpful
GE Profile Spacemaker xl 1800 JVM1860SD. Touchpad has stopped working.When power is turned on -get error message F3
F3 means you have a shorted membrane keypad.
The keypad is not available as a separate part, so you would have to order a control panel frame assembly, which comes with a new keypad on it.
Whether your model number is JVM1860SD001 or JVM1860SD002, the part number is WB07X10474 and a link to various suppliers is here.
They're not making these anymore, so order while supplies last.
This is a simple DIY job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and carefully move your circuit board into the new frame.
Some connectors on the relays have a lock:
10 yr old hotpoint Microwave model #RVM1325BW will not heat, vent,clock, touch pads all working.Hust no heat. If this needs to be replaced what model # should I get for the same dimensions?
I would say that your heating element has gone out. I don't know exctly what model you have, but I would guess it to be about 1.5 Cubic Ft., and a replacement would probably run somewhere around $150 to $200. There are many brands, but if I had no cost to consider, I'd probably go with a GE or Kenmore. Hope this helps.
Kenmore microwave model 721.80033700 won't heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
5helpful
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
No lights not working at all
Model JVM1860SD001 lights quit working. Replaced all 3 bulbs (2 in range and 1 oven light). Everything else works fine.
No heat
Most common causes for no heat is bad magnatron, capacitor, or diode. This should be checked by a certified technician due to high voltage. Microwaves come with a 1 yr warranty from date of purchase and in some models the warranty is longer on the maganatron. Will need to check the owners manual.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
