I've tried installing the software provided by Sony for both capture and controls but neither work with Windows 7 (64-bit). Through Device Manager, the webcam is labeled as 'USB Imaging Device' but not 'Motion-Eye Webcam'. I've uninstalled the drivers, re-started the system, and gone through Windows update several times. When I try to update the drivers manually, it says "Windows has determined that I have the most up-to-date drivers available." When using ArcSoft, it says "Camera isn't connected or it is in use by another application. Close any application that could be using the camera and try connecting it again." The same is said when using Skype.. "Skype cannot connect to the camera because it is in use by another application." This is after a re-boot and Skype is the first application that I run. What would cause this to happen?
SOURCE: sony vaio motion eye
I have windows vista sony vaio vgn fe880e buying at america, but I dont have drivers of motion eye web camera
You will need to get XP drivers for the product, they can be found here.
SOURCE: my sony vaio webcam not working
if you remember the date on which it was working with webmax you can try windows vista system restore feature and restore the system back to the date it was working on
here is an helpfull link
http://www.bleepingcomputer.com/tutorials/tutorial143.html
further Queries are welcome
SOURCE: Installed drivers but Motion Eye is not even acknoledged
Did you try any of these
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGN-FJ270/B®ion_id=1
good luck
SOURCE: motion eye webcam for sony vaio vgn-z610y running vista stopped working
Install the latest WEBcam driver.
You can download the device drivers from the Sony WEB site.
Select your model notebook and the Windows drivers you require. Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
