Radio Communications Logo
Mike Runyon Posted on Mar 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What's is the rep +100 in the vfo programming list?
jeff5may32
Level 3:
  • Master 1,258 Answers
  • Posted on Mar 16, 2015
jeff5may32
Master
Level 3:
Answers
1258
Questions
0
Helped
375648
Points
5289
VFO mode is where you spin the dial yourself, and memory mode is where you pre-program the fixed frequencies you want (a.k.a. "favorites) (via a button when you are at a certain spot or with the keypad) into the various memory channels. REP+100 I imagine stands for "repeated 100kHz". When the radio is in VFO mode, pushing the button or turning he knob will change the frequency in this step repeatedly.
ka4iup
Level 3:
  • Master 4,062 Answers
ka4iup
Master
Level 3:
Answers
4062
Questions
0
Helped
1096723
Points
51404
What is the manufacturer,make and model number of your radio?
1helpful
What are the tuning steps /procedures on a Yaesu FT 225DR. Works when tested my friends bench but not in my shack. All other 2 Meter rigs have no problem. The manual does not have this. PLEASE HELP.
You mean FT-225RD not DR ?
The RD is a base station all mode 2 meter rig. Older model.
Set the Channel switch to VFO.
Use the Band selector to set the vfo to 144, 145, 146, or 147 mhz.
Then turn the vfo knob to select the frequency.
ICOM IC-R6 is scanning very slow. 1 frequency in 2 second, not 100 frequencies in 1 second. Where is problem ? How to change speed of scanning in IC_R6 ?
The Fix
Programming via CS-R6 with Windows 10 made the problem. Scanning was very slow.
The CS-R6 program through Windows 10 made problems with the scanning speed - it became very slow, one frequency in 2 seconds instead of 100 frequencies in one second.
Through programming CS-R6 on Windows 7, the scanning speed returned to the corresponding one in the ICOM instructions - 100 frequencies per second
How to modify kenwood th234 from channel mode to vfo mode?
[PDF]Page 1 INSTRUCTION MANUAL KENWOOD ...
manual.kenwood.com/files/B62-0790-10.pdf
o Contains 60 memory channels programmable with desired frequencies and ... o Do not modify this transceiver unless instructed by this manual or by ... BASIC TRANSCEIVER MODES . ..... 1 Press [VFO] to select VFO mode. P1'I switch, and ...
[PDF]INSTRUCTION MANUAL - Kenwood
manual.kenwood.com/files/TH-D7-English.pdf
memory channel to be named using up to 8 ... Do not modify this transceiver unless instructed by ...... In VFO or Memory Recall mode, use the keypad to select a ...
Modifying the Kenwood TH-78a handheld transciever
www.welcomehome.org/rainbow/.../kenwood/kenwood-th78-mods.html
Nov 17, 1995 - (When William's early-model TH-78 was upgraded his mods (removed .... channel (if in memory recall mode) or last frequency (if in VFO mode).Missing: th234
3helpful
IC-R75 VFO freeze
This sounds like a failure of the VFO encoder, which can be caused by a static discharge from your hand. Check to see if your grounding wires have been loosened. If this is the case, then static discharge is the most likely culprit. ICOM is very good about repairing radios and getting them back to you quickly, but it is of course cumbersome at best to send radios through the parcel service.
Baofeng uv-5r will not transmit
Sounds like you have the transmit lockout set. this radio is a bit of a pain to program, but is well worth the effort. your best bet is save your settings (backup) and do a full factory reset, and start over, making sure you did not lock out the transmit on any channel or VFO...
Help!i have just purchased an i-com R5 the manual keeps referring to the VFO,i know what it means but how do i know when the scanner is actually in the vfo mode??? deranged of swansea!!!
VFO stands for Variable Frequency Oscillator. This is the function that allows you to enter frequencies. It just means you are not in memory channel mode. You can get more info at the factory web sight and download the instruction manual for free.
http://www.icomamerica.com/en/products/receivers/handheld/r6/default.aspx
1helpful
I have need to program's Creative camera vfo 220 to download . Many thanks ahmed fahmi [email protected]
Check out the Creative support website
http://support.creative.com/Products/Products.aspx?catid=218
1helpful
Fix it 10 software removal
Buy the program again install and un-install?
That is with out a doubt the most asinine thing I have ever heard. Ignore him and try booting into Safe mode then run the add /remove program. The software is simply loading with the system files and once activated is difficult to remove while the Fix-it files are running. Many spyware and Virus programs do the exact same thing.
Running in safe mode loads just the bare essential files Windows needs to run. All others are skipped..
If this fails, try downloading and installing Revo link here.
It will ask to search the registry for stray entries left behind. Let it do this, but be careful deleting the registry entries. Be sure it is a stray from the Fix-it utilities. You can usually tell by checking the entry displayed.
Revo is a powerful clean up tool.
It will TRY to use the programs un-installer first.
"Most installations set up a "un-installer" file.
If Revo does not find one, It will automatically go to the next phase and do it's best to locate all the bits and pieces and purge them.
Hope this helps!
1helpful
I dont know how to program frequiences on the scanner
1. Press Menu (Bottom left hand side of the scanner) You should see "Program System"
Press E You should see "Select System"
2. Turn VFO knob (Top outside right knob on the scanner as it faces you.) until "New System is displayed.
3. Press E
4. Using the VFO knob, select "Conventional then press E three times
5. Press the decimal key until all the letters under "Edit Name’ disappears
6. Now you’re ready to name your system. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
7. Turn VFO to Edit Group then press E
8. Use VFO to select New Group then press E twice
9. Press the decimal key until all the letters under "Edit Name’ disappears
10. Now you’re ready to name your group. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
11. Turn the VFO to Edit Channel then press E. (You should now see "New Channel")
12. Press E then enter a frequency
13. Press E twice
14. Press the decimal key until all the letters under "Edit Name’ disappears
15. Now you’re ready to name your "Subgroup" i.e. " Dispatch" Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E then menu
16. Use VFO to select New Channel
17. Repeat steps 12 through 16
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
