SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
SOURCE: My Candy GrandO washing machine is boil washing
sounds like overheating, don't use until you have had it checked, may be dangerous
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses
and check for blockages. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the
correct
type of soap so the ball check valve on the bottom of the outer drum
isn't
getting fouled with excessive suds. Also disconnect the drain hose from
your
house plumbing and let it free flow on it's own. This will tell you if
the
block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Your pump/filter is plugged. (E4) There
is a round door on the lower front of the washer. There is a small hole near
the door. Put a small screwdriver blade in the hole, push in just a little, and
you can rotate the door clockwise, the door will come out and you can get to
the problem. When the water is drained
in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter.
When you unscrew this, all the water left in the washer will spill out onto the
floor. Use a plastic bag to catch this or a small pan.(later models have a
drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find
the source of your clog. Remove it, clean out, screw the black connector back
in. You can check with rinse, if you
want to make sure there are no leaks. Put
the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
