With the error that you're getting with your Canon mp258 , error number 6000 this means that your printer needs to be reset. You will need a software resetter for this specific printer. You may also use the software resetter for its many other errors. Kindly click on this link for the instruction and for you to be able to download the service tool. This should fix the error code that you're getting and other issues with your printer.
You will need to reset your printer and this printer requires a software resetter fo many of its error codes. The newest and best available resetter with full instructions is available here. Just follow the easy instructions and download their service tool and this should reset any error codes or problems you are having with the printer. Hope this solves your issue.
Canon Printer Error Code 6000 is one of the typical errors that occur very frequently. It happens while users are attempting to print all of the printer's documents. The problem of Paper Jam is the main cause of this failure. There are several explanations why Canon Printer Error 6000 will happen when you work with a Canon printer. One of the factors is that one of the most simple common explanations is where the paper feed tray is blocked by certain dust particles and bits of paper. Another reason for this is that the paper feed tray is not adequately connected to the printer. If there is a tonne of a print order.
Reasons that cause Canon Printer Error Code 6000:
1. The feed tray of the printer is improperly fitted.
2. A large number of documents near the printer.
3. The line feed is scratched or smeared.
4. Giving multiple paper print commands at once.
5. Faults within the sensor unit or in-line feed slit.
Hi there it is ink error. You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Start with printer off
Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
While holding the Power button, release the Resume Button.
Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
