Rv air conditioner was accidentally hooked up to 220v. Popped breaker a couple times b4 realizing. Now it don't cool. Just runs fan on cool or fan only. What/how do I check for the problem? And can you buy parts for these. Some say just replace unit. Hoping to save a few bucks. Did work just fine.
    Master:
  • 602 Answers
If the unit had fuse or thermal protection it would not have popped the breaker. The compressor got zapped along with other components. Save a few bucks. Replace the unit.
Posted on Mar 16, 2015
6ya staff
SOURCE:
Anonymous
  • 59 Answers
SOURCE: Outside Unit Air Conditioner fan not running
probably a bad fan motor. could be a capacitor
Posted on Apr 25, 2009
Bill Long
  • 606 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
Anonymous
  • 614 Answers
SOURCE: can my duo-therm air conditioner on my rv be recharged?
These unit can be recharged. 134A. You NEED A SERVICE TECH THAT KNOWS HOW TO CHARGE UNIT.RUS
Posted on Jun 25, 2009
Keith Fournier
  • 308 Answers
SOURCE: The outside unit is not working on my Heil Air conditioner
The attic fan is not a part of your a/c system, and you should not run it while you are running the a/c. If you are currently using the attic fan, it is possible that someone wired it so that the a/c won't turn on while the attic fan is on. Otherwise if the thermostat is set below room temp, and says it is calling for cool, then the problem is most likely coming from an issue at the outside unit itself. Make sure to check your fuses, at the fuse panel and outside breaker. Hope this helps
FYI.. the only part of the system that might use batteries is the thermostat.
Posted on Jul 28, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: RV Air Conditioner Keeps Tripping Circuit Breaker & Compressor
It sounds like the unit was miswired at the factory, since when the A/C is "off" at the thermostat, there should be no calls for cooling or for the fan to run.
You also stated the most puzzling issue, with the breaker turned "off" the same thing happens. This shouldn't happen at all, when the power breaker is turned off, there should be no power being supplied to the unit and it shouldn't be able to do anything. Very strange indeed, but likely a major error done when the RV was manufactured, or some wiring in the loom has somehow become shorted and is supplying power from another breaker/source.
I think a call to the manufacturer is in order since there is no easy solution aside from possibly rewiring the A/C circuit.
Not sure when your RV was made, but definately time to call the manufacturer and break out the wiring schematic in an attempt to isolate and resolve the problem.
Hope you find this helpful and best regards!
Posted on Aug 06, 2009
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
MY AIR CONDITIONER WILL WORK GOOD FOR ABOUT 10-12 HOURS AND THE NEXT DAY I WILL AND CHECK THE RV AND THE CIRCUIT BREAKER WILL HAVE POPPED WHAT WOULD CAUSE THIS TO HAPPEN. IT COOLS GREAT. THANK YOU
most likely the condenser is very dirty and the compressor pull more amps than is suppose to and when this happens the breaker tripps.start by cleaning the condenser with a design conderser cleaner.
Aug 12, 2010 | Dometic Rooftop RV Air Conditioner
My a/c comes on fine; however, if the fan is on low it kicks the circuit breaker after a couple minutes. It works fine on high.
Feel the compressor it may be getting hot and the increased
air flow on high may cool it somewhat.
If so compressor problem or much slowed fan
Check air volume on low.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Dometic Rooftop RV Air Conditioner
Aug 06, 2009 | Dometic Rooftop RV Air Conditioner
Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Duro-therm rv roof a/c..model 57915.331...compressor coming on..fan not running..after a couple min. breaker trips....fan will not run on manual or auto...help,blackie williamson
Either your fan is stuck due to age or grime or is shot
if the fan does not provide cooling then the unit goes into thermal protection mode and shuts down
Jun 09, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
