The cold/cold on dial doesn't come on but on the cool/cold I get only hot water on this!
Obviously the first thing to check is that water is coming through the cold hose some times the on off valve for the hose can get blocked or has not been turned fully on and lime scale blocks the remaining flow. if you have water coming out of the hose swap the hot and cold over this will give you the major insight as to the valve on the back were the hose connects is working listen to see on a cold setting if the valve buzzes like the hot does if not and you can cold fill by having the cold & hot swapped then it is the inlet valve that needs swapping out for a new one.
Change fill valve
Not sure what ur saying have u tried changing the hot cold hoses and see what happens? u may have a bad water inlet valve or a bad water temperature switch? first make sure ur getting hot from the house outlet, u can check with a multi meter for continuity to see if either is out
