If the computer was working before you changed the power supply then likely you have not connected all the header wires properly. Check your wiring again. If you replaced the power supply because the computer was not working, then you may have an issue other than power supply, such as a bad motherboard.
Testimonial: "No fans are not running is other way power it on"
So before is other way can get power on the fans not going
