A
Abdullah Khalili Posted on Mar 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i fix Error E007 on Canon IR 2016j?
I have Canon IR 2016j photocopy machine and it displays Error E007. I tried clearing the error using function Key 2&8 Function key and after restarting it displays again that error. how do i fix it?
sahoo_sanjay
Level 3:
Master:
  • Canon Master 553 Answers
  • Posted on Mar 15, 2015
sahoo_sanjay
Canon Master
Level 3:
Master:
Answers
553
Questions
0
Helped
218778
Points
1676
Dear
Replace the fixing film assembly or fixing film.
Thanks.
Testimonial: "Thanks i'll try replacing fixing film. i hope it works"
I have a canon photocopier ir 2016j. I changed the drum and blade. after installing, I received a system error e007 on the screen. can someone help me?
It is Error in the Fixing Unit Film.
First Go to service mode and clear the Error.
Power the machine and On the machine if problem persists Replace the fixing unit Film
COPIER>FUNCTION>CLEAR>
ERR.
I have canon Ir 2016j photocopy machine and it displays system error how do i fix it?
Have you tried unplugging the machine for a few minutes and plugging it back in?
2answers
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
How can i fix an E007 error code on CANON IR 2022?
Ther's aproblem with fixing unit. Usualy the fixing film has to be replaced
1helpful
4helpful
2answers
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
3answers
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
24helpful
4answers
Canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
82helpful
5answers
I have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
old marine
old marine
ZJ Limited
ZJ Limited
