Vehicle Parts & Accessories Logo
s
serban badea Posted on Mar 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No stop lights - Vehicle Parts & Accessories
Kardoc
Level 3:
Top Expert:
  • Vehicle Part... Master 7,503 Answers
  • Posted on Feb 26, 2019
Kardoc
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2759804
Points
58323
Check fuses for stop lights
Why does it keep stopping with lights flashing when filling bobbin?
Singer 7422 keeps stopping with lights flashing when filling ...
www.fixya.com/support/t26006759-singer_7422_keeps_stopping_lights
4 hours ago - Singer 7422 keeps stopping with lights flashing when filling bobbin Machine stops ... Machine stops and red lights flash when loading bobbink.
Brakes lights stopped working
Check stop lamp fuse 1st, possible failed stop lamp/brake switch.
Engine light goes off and on while driving and stays on when stop
The stop light has a bad ground.
-Check the stop light 's wire and reconnect the ground to a good clean
metal surface.
Mai Lor
Trying to replace the stop light switch on a 1986 toyota 4runner
Move into a position where you can easily see underneath the driver's side of the Ford pickup's dashboard. How you do this depends on your physical size and dexterity.
Shine the flashlight on the brake pedal arm to illuminate the stop light switch and the stop light switch mounting bracket. Unplug the Ford pickup's brake light wiring harness from the switch by hand.
Read more: How do I Replace the Stop Light Switch in a 1986 Ford Pickup? ' eHow.com http://www.ehow.com/how_7655525_do-switch-1986-ford-pickup.html#ixzz21tSRtoDU
Unbolt the stop light switch from the stop light switch mounting bracket using the box wrench set. Take the old switch down by hand and place the new switch on the bracket.
Bolt the new stop light switch to the bracket with the socket set. Plug the brake light wiring harness into the Ford pickup's new stop light switch by hand.
2007 dodge caravan keeps blowing 20 amp fuse for signal lights
American vehicle with them funny stop lights that stop working to allow the indicator to flash the bulb and i suspect that it could have a fault in the stop light switch which has a lot of wires running to them unlike a europeon vehicle with yellow seperate indicator lights and only two wires to the stop light switch
I have a 1998 honda accord. the tail lights work but when i hit the brakes the lights dont get brighter
the tail lights and stop lights are two separate bulbs or elements. You either have a blown stop light fuse or you need to replace the stop light bulb.
hope this helps.
2answers
Battery light brake light and stop lamp light on
Sounds like you have a broken belt for the alternator and power steering.
3helpful
3answers
FOUR LIGHT GLOWING WHEN EVER HEARING MP3,I WANT TO STOP IN ALFATEL H1 MOBILE
to stop the four lights, goto settings --> phone setup --> set Run Light. select the option off.
1helpful
2answers
2003 silverado 1500 v-6 brake lights dont work
ljones, Did you check the "VEH stop" fuse in the left side instrument panel fuse box. There are 3 stop light fuses, 1 for all the stop lights located in the under hood fuse box. 2 in the left side IP fuse box. 1 for the upper stop light and 1 for the lower stop lights. The fuse box in the IP is where the upper and lower stop lights split. Let me know.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
