If you are talking about low voltage light transformers, then answer is probably NO... but you could try it and see if it works... but I am almost certain that both transformers will probably burn out.
Output is 12 Volt AC... the transformer coils will probably burn out because the waveform from each transformer cannot be guaranteed to be the same.... even if both transformers are seemingly identical and plugged into same outlet.
For additional information, read transformer installation tips on following page.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
Power company transformers can be wired together in specific ways to produce 3-phase waveform, but these transformers are specifically engineered for the task. And the transformers do not combine the output (as you would be doing with yard transformer), instead each power company transformer produces 1 leg of power in a 3-leg power supply.
http://waterheatertimer.org/What-is-3-phase-electric.html#transformer
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
