SOURCE: My web camera isn't working.
Check the driver if is still at hes place , if is not there go to manufactor website and dowload the driver
SOURCE: how does the built-in camera of ideapad y430 with vista work??
This is the technical support telephone for the Lenovo Notebooks in the
USA. You can call them for any troubleshooting problems. I am sure they will be able to help you get the operation of you web camera back to normal. Thank you for using FixYa and have a nice day!
United States
English
1-877-4Lenovo (1-877-453-6686)
Notebook
24 hours a day 7 days a week
IdeaPad & Netbook
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: help to install memory on a lenovo laptop y550
1. remove the battery first by turning the notebook over. unlock and hold the latch, and remove the battery.
2. remove 4 screews on the CPU door and then remove the thermal door. (see picture 1)
3. Pull the two latches securing the memory and pop the memory module up to 45 degree angles, and then pull out the module in that angle (see picture 2)
SOURCE: I have a Lenovo ideapad
Welcome to Fixya
THis means that the bootmanager is corrupted. You can still use the computer by pressing the One key recovery button. Look for the button located beside the power button that has a U-turn sign icon. Press that button once whn the computer is turned off. This will restore the computer back to factory defaults. Please take not that this will delete all files and data inside the computer.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
