SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
SOURCE: will not drain after the wash cycle, will not enter the rinse cycle
It sounds like the lid switch is bad.Does it act as if the lid is open even when closed? A common problem is that its mounting method fails (breaks off) after some time. Quick way to test is:
Find the plastic striker in the lid and under matching hole in the washer's top you should be able to find this switch. Try to operate (close) that switch with your finger or a screw driver and operate the washer while holding it down. If now it works, the switch is the culprit. Available on-line around $30.
SOURCE: leaking
The pumps usually have rubber hoses fitted them and they can deteriorate over time, moreso around the clamps that hold them onto the pump. Also, maybe the pump has been slightly opened via a worn seal. Either way, there may be a risk of fire if any water gets onto the electrical connections of the pump or spray onto any other open electrical connection inside the machine. It would certainly be advisable to have it checked with some urgency.
During the final rinse and spin, I would think the pump may not be used during these cycles.
Hope this helps somewhat.
SOURCE: Whirlpool Front Loader machine will not drain
On our LHW0050PQ the "Done" light stays on solid-- it does not blink, so on yours it may be indicating a malfunction, either in the electronic control or a problem with the pump. As VersaStyle suggested, you can check the connection to the pump, check for power to that connection and also look for evidence the impeller might have a pin or something stuck in it. If it used to work and it made a lot of noise before failing, I would suspect an object lodged in the impeller or a seized bearing.
(I find that when I use non-HE detergent, the pump gets really noisy, making sounds like the bearing is going out. I have a solution for that, but your situation sounds like a complete failure somewhere.)
SOURCE: Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
