Jennifer,
A lot of times, the cause of this is the water valve not sealing off completely and allowing water to continue to come in. There could be several causes for this. There could be a hole in the diaphragm inside the valve, there could be debris that got through the screen and is stuck on the valve seat. If there is a hole, the only way to repair is to replace the entire water valve. If there is debris that is stuck, you can dis-assemble the valve and clean out the debris and put it back together and then put back in the machine and try it out. Most of the time the valves are not very expensive and they do not take a lot of time to pull out that most people just go ahead and replace them so that they do not have to dis-assemble them. Hope this helps
